Question about Tatung V30DMTT 29.6 in. LCD Television
Emprex HD-3201 will not turn on. I push power button and nothing happens.
    Problem Solver:
  • 18 Answers
Did you fix your Emprex yet?
Posted on Jul 11, 2009
  • Rich Glass Nov 06, 2013
    I have not been here in foreva. lol. The power supply is the culplit in this case. I have a perfect one as well as all parts for this model.
  • 3 Answers
Common problem w/Tatung-go to local computer guy and have him re-build power supply,faulty diodes
Posted on Mar 04, 2009
I HAVE AN AKAI HD TV DVB-T32W. When I started out first time, it autoscans but found no channel. press DTV or ATV, it,says "No channel. need to rescan". But nothing happens, thanks
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 09, 2017 | Akai Televison & Video
Hi Bush tv is flashing but not turning on at all. What can i do?
Hi press & hold on-off button while holding unplug power plug from the wall continue holding for 30 seconds.,.Plug in the POWER plug while holding on/off button hold for another 30 seconds ......,.Good luck.,
Jan 08, 2017 | Televison & Video
Sound is pinned at 100% output. Remote nor physical buttons on device are working.
If any of the buttons on the remote or tv work, then try going into the menu and turning the sound down manually.
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
I can't get my Comcast remote control to sync up with this sylvania 32in HD tv. I tried every code in the Comcast DVR manual under sylvania tv's and nothing, I would love a fix to this problem.
the tv is likely to be generic in nature i.e. parts used by many manufacturers. if you knew what tv builder actually designed it you could find the code. does the remote have a search feature if so use it, it should find something that operates most tv functions eventually
Mar 09, 2013 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
URC-22B doesn't work with my BEKO tv.
Check with this method. Manually turn on your tv.
Then push and hold the code saerch button until the light stays lighted release the button.
Push and release the device button you want to set TV.
Now you got to push and release the ON/OFF button until your device turn off when your device turn off stop and push and release the enter button for storage the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Jun 12, 2009 | Televison & Video
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Tatung V30DMTT 29.6 in. LCD Television Logo
1,436 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
