Question about Roper RAS6233KQ Top Load Washer
RAS6233KQ0 Doesn't Spin
We just received a Roper RAS6233KQ0 which will not spin up. It starts, aggitates and drains, but no spinning. with our without a load in the barrell it does no spinning.
  • Roper Master
  • 3,361 Answers
Manually set it for SPIN and turn it on.
If it does nothing at all,
You have a defective lid switch.
Jumper the lid switch and see if it spins.
If yes, replace the lid switch.
Posted on Feb 27, 2009
Roper washer rax7245awo won't spin/aggitate
is this a top loader??there are clips on the edges of the top..they require use of a regular screw driver(flat blade) inserted between the top and sides..them it should pry up and tilt to the back..on hinges..
Feb 02, 2014 | Roper Washing Machines
STYLEMATER 4214164, AGITATOR SEAMS TO BE STUCK,
are you sure it's aggitating?common problem with direct drive washers is the motor coupling breaks and the transmission can't engage with the motor or you could have a bad transmission.usually you'll find oil leaking out of the ******. you can check this and the coupling at the same time.one other thing,when in spin open the lid and then close it and listen for a clunk and see if it spins,that would be the clutch on the ******.if this happens see if you can get it to spin in any other cycles,i've had bad timers do this,if it spins near rinse but not in the final spin and if you open the lid,close the lid and then the clutch falls and it does spin i'd say you have a bad timer,you can watch the timer,if it moves all the way to end but it doesn't spin in the same spot on the final spin but does spin in any other cycle it's the timer.but check the coupling first.http://www.youtube.com/watch?v=9K1KHEogf3c copy and paste,it will show you how to get at the coupling.
Oct 30, 2011 | Roper RAS8445KQ Top Load Washer
Won't spin out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Roper RAS8244KQ Top Load Washer
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
361 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
