Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Jvc av-48wp74 i have sound but no picture History I have a JVC AV-48wp74 Projection tv when i got this tv the stk ic's were overheating and the picture would come and go typical of overheating . I put a fan on the IC's to figure out that they were bad. I replaced the Convegance board (new)everthing seemed to be good Except it was still over heating. So i installed 3 little box fans to keep things cool . But during the install i by accident crossed a ground to a diode on the LCB10219 power & Def pwb board in the V def section . I replaced the La7876N ic chip and were i think it shorted d407 and d402 and the fusible resistors . But while soldering in the LA7876N ic the copper connections got overheated and damaged , So i replaced the P/N LAC10219 board with one that was out of a AV-48wp30 P/N CKG0256-AM1-1 only because it looked identical (used part). But now that it's replaced i get sound but no picture (Any ideas would help) not sure maybe the av-48wp30 P/N CKG0256-AM1-1 will not work in my tv i have. I did notice a reistor is not on the av-48wp30 CKG0256-AM1-1 board but its on my LAC10219 board. Also the sub def pb assy (maybe onsreen board)is allot different looks the same but the green side is different. So i am using all the av-48wp30 parts (P/N CKG0256-AM1-1)on the left side of the tv which could be the problem,but it does hook up the same way and to the right side board. Any Ideas and thoughts would be allot of help Sound but no picture i hear the channels and snow ,picture screen i see the red green and blue in the form of 3 wavey lines in the top center the rest is black and no OSD onsreen display If you need anymore info email me
  • James Waters Feb 27, 2009
    when the convergance board was replaced with a new one i did a a automatic convergance allignment everything work except the overheating and i needed to replace it because i tried to put new stk's in but overheated and damaged the board as for the rest of the stuff you are talking about there i don't have a picture with cable or video in and no OSD just 3 tiny lines at the top left to right overlapping and a wave that bows down in the center of the screen
    President:
  • JVC Master
  • 1,779 Answers
Number 1- don't spin your wheels on the replacement board repair the old, it can't be unrepairable. As for the over heating of the conv ic's not normal. Since you changed the conv bd and they still over heat, if I had the set I would do a reset of the registers in the service convergence mode then re-center the grn then red then blue and that will be with the centering magnets and yoke on the crt's, If you don't have a template for that then you will have to make good old fashion geometry measurement's, the green is first, every line straight vert, horz, and spaced, with of coarse the cross in the middle will be dead ctr. The overheating problem can be because the register settings are advanced to far do to corrections thru out the years with comp's changing in value and us compensating with adjusting the convergence.
Posted on Feb 27, 2009
  • Jim Krause Feb 27, 2009
    The only thing I can think of for the overheating is a possible bad yoke, and again, the register settings, not the auto convergence. If your vcc to the ic's is good then that takes care of the supply. The only things left are what I mentioned, providing the ic's are ok.
Jvc 48 inch tv and the picture looks 3d
Convergence ICs have failed. You can get the convergence repair kit for your model JVC at www.tvrepairworld.com the kit contains both ICs the associated resistors and the CD with detailed instructions.
Jan 03, 2010 | JVC AV-48WP74 48" Rear Projection...
I'm looking for a replacement convergence board for my Jvc AV48WP74 tv. SSB-5068A-M2 I've replaced the STK392-150 ic's already and after a week they failed again. JVC does not return my calls.
A Google search for the board part number returned several sources. Here's one. You should also check the values of resistors around the STK's. When the IC's fail, the resistors can change value which can cause the repeat failure you're experiencing.
Sep 24, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
BLURRED DOUBLE IMAGES
need to replace convergence ic stk392-110
May 07, 2009 | JVC AV-48WP74 48" Rear Projection...
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 IN
You will need two STK 392-110 ICs. They are located in the front of the TV. remove the speaker grille and then the small access panel and you will see the convergence board it has two Black heat sinks the ICs are mounted there. You can get replacement ICs with free shipping and free instalation instructions at the following Link.
http://servicemanuals.vstore.ca/
Jun 23, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC MODEL AV-48WP74
Convergence Issues Both STK392-110 ICs and possibly the 1.8 ohm and 1.5 ohm 1 watt convergence resistors as well. You can get replacement parts at the following link and they provide free instalation instructions
Jun 20, 2008 | JVC AV-48WP74 48" Rear Projection...
Flashing power light on JVC 48W TV
Tri to remove the concergence pcb assy and start the Tv.If the TV is working just replace the convergance IC.
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergance Board JVC AV-48WP74
it will have a large heatsink with at least two large IC with the numbers STK392-xxxx
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 09, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
280 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
