Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Drips water out of Ice maker spout
On the freezer outside door where you have a choice of Water, Crushed Ice, or Ice, water drips out of the spout where you would get water. Is there a valve that is leaking and can be replaced? I have chosen a model below but I am not sure this is the exact model that we have.
  • davidbecker Feb 27, 2009
    I will take a look at this and let you know how it turns out. Thanks for the help.
  • 4 Answers
There is a valve that controls the flow of water at your door. Take the front console off and take it out. There will be wires attached to the console for your water/ice control so make sure you either tag or write down where these wires go. Then replace the valve you will clearly see that opens the water up. Take down your model and serial number down and go to your local appliance dealer so they can cross reference the part number OK? Randy B. A.I.R. Appliances
Posted on Feb 27, 2009
My freezer is not making ice and the water only drips out of the water side
There could be a couple dif problems. If the temp in the freezer is not below 6 degrees the thermistat in the ice maker will not call for water. The selinoid in the water inlet valve for the freezer may be bad. The ice maker itself may be bad.
To test the inlet valve switch the hoses and see if it calls for water when you call for water in the door. To do this you will need a 1/4 inch nut driver. Remove the panel in the back of the fridge on the outside. Push the connector inwards and pull the hose out. Most inlet valves you can do this with. Switch the hoses and push the water through the door button . If you cant do this you have 2 choices. Either call a technician to test the inlet valve or take a gamble and replace and hope this works.
If the inlet valve is good and the freezer temp is below 6 degrees replace the ice maker.
Jun 30, 2011 | Whirlpool 21.7 cu. ft. Side-by-Side...
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker drips water into ice tray
Probably the solenoid valve leaks(electric valve that opens when the ice maker calls for water) and overflood the ice maker,the only way to fix this is replacing the solenoid.
Sep 22, 2009 | Kenmore Refrigerators
There seems to be ice stuck in the little slide to
the best way to defrost this is use a blow dryer in the comparment and th a towel or shop vac to soak up the water
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
