Question about Husqvarna Garden
Stop button not working
My Husqvarna 350 chainsaw will not stop unless i use the choke. do you have any suggestions on how to fix that problem?
    President:
  • 2,692 Answers
A stop button is just an on off switch or a monitary off(Short) switch which shorts out the primary to the coil. Either the switch is broken , the ground wire not making good ground or the primary wire to the switch is off. You can get any two position switch, (for example from radio shack) and replace it withhe noew on if the switch itself. Trace the two wires to see if they are connected. Most likely is the ground one is off or disconnected.
Posted on Feb 28, 2009
Husqvarna 350 chainsaw does not run in the cold?
doesnt this one have a little blue choke lever you pull out ? not there anymore ? they do sell parts for these still !!
Feb 28, 2015 | Husqvarna Garden
Husqvarna 350 oiler swap ?
Not as far as i know, ive checked both parts manuals and they both have two different part numbers which would suggest they are different.
Jul 13, 2014 | Husqvarna Garden
How to remove carb on 350 husqvarna chain saw
Remove the air box cover and remove the air filter. You will see 2 screws going into the carburetor. These 2 screws hold the carburetor onto the saw. You must use care (and take a couple pictures) to see how the linkage fits back onto the carburetor. You will also see the choke and kill button on the left hand side. Take you time and you should be fine. The throttle linkage is the hard part.
Jul 08, 2014 | Husqvarna Garden
Kill switch on husqvarna 350 doesn't work
call your local or home repair shop/do not kill the motor by choking it out. also you may just have a wire come loose.
Oct 26, 2012 | Husqvarna Garden
Have 350 saw and the stop button does not switch of the saw Inow have to pull the choke out to stop the engine.can you advise please. Thanks John Mckenna
This is caused by either a faulty stop switch (check for continuity with a multimeter), one of the leads has become detached from the switch or is broken, or the lead from the switch to the chassis of the saw has gone open circuit. The stop button functions by shorting the output voltage of the magneto coil to ground.
Feb 22, 2011 | Husqvarna Garden
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a husqvarna 36 chainsaw that starts and runs just fine. However, the stop switch doesnt seem to work. I push the switch to stop and the saw continues to run. The only way to kill it is to use the...
Hi
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Bob
http://www.airtimeproducts.com.au/assets/docs/Husqvarna%20service%20Manual.pdf
Aug 13, 2010 | Husqvarna Garden
Brand new husqvarna chainsaw won't start
A commen problem is flooding the engine.
A good way to start it is to press the fuel pump balloon three times choke it. pull once...pust the choke back in so that its stops choking and give it a few swings then it should start.
i am asuming you have put the on of switch to on.
Jul 11, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 350 wont stay running?
ok,  The choke is used to change the air/fuel mixture by "choking" off the air that goes to the carburator.  The choke is only used to get the motor running in cold temperatures.  Once the motor is started, the choke must be opened or the motor will flood and stall when you open the throttle.    I hope this solves your problem.  Best wishes, Michael Mittelsdorf
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
419 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
