Question about Canon T90 35mm SLR Camera
I just loaded up my old T90 after 4yrs of non use. All was well, the display showed mode, shutter speed etc then when I took the first shot I got HELP in the viewfinder and the three EEEs on the lcd. I took the batteries out and tested them - all ok. When I re load the batteries the lcd shows one shot taken and all the normal settings again. I take another shot and the same HELP and EEE errors come up - if I take out the batteries and reload then the camera works again. I have tried moving the film winding to HIgh taking a shot and switiching the dof preview on and off but this has not stopped the problem - should I try to lubricate the dof switch?? If so how do I do this? All answers gratefully received :)) THanks Lin
  • danijel_zele Apr 16, 2009
    My lcd on T90 Canon's  camera shows ''EEE'' and shutter's not working.I've heard that this eror came up because, the motor's electro-magnets on the shutter are sticked. Tried to open it,but I've stoped when I saw very complexed mechanism.Is there any chance to fix this problem on my own,with Your HELP,of course.Forgive me because my knowledge of English, is not so good,and I make many writing mistakes.
    I'm looking forward for any help from You.My location is Bosnia and Herzegovina,and we don't have any certified services for Canon.At the end,THANK YOU.
Lin & Daniel,
I had the same problem w/ my T90 after years of not using it. But, the T90 is not dubbed the Tank for nothing. The shutter curtains stucked/stacked because of unuse, especially if you hadn't used it for years.
Here's what i've done to revived it:
I set the shutter speed Tv 500 in Low then hit the carpeted floor while pressing the release button.
Try it my friends and let me know.
http://cyberman9.multiply.com
Posted on Jul 21, 2010
  • 538 Answers
Advance Drive Motor needs replacement.
Posted on Apr 02, 2009
Exilim underexposed
Making copies of old photographs sometimes requires special lights and equipment such as polarizing filters and specials polarized lights, If you are using available light you automatic exposure system in the camera is probably selecting a slow shutter speed thus resulting in blur. or perhaps overexposure.
Quick method- Take to picture out of doors in hazy sunlight or open shade, hold the camera firmly and try the shot again. If that does not work- tell me what kind of camera you are using and how and where you are shootin.
Ed
Aug 03, 2013 | Cameras
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Shutter speed
On most fuji cameras the programmed shutter speed for the sports or action mode is 1/1600. This is the mode you need to use. You should not have to change the aperature unless you have a problem with the light. This is the most difficult shot to make with a digi cam. So make sure you use a larger steady tripod for this shot (If you can't use a tripod crouch down on one knee and use the other as a support.) Keep a steady hand and don't make the mistake of creating camera shake by hurrying an action shot. I focus a little ahead of my subject, then snap the shot when I see they appear. This method even works with lightening. Practice making this kind of shot. You can get very good shots with some care and practice. Good luck.
Aug 07, 2008 | Fuji FinePix S3500 Digital Camera
Action shots
Action shots generally require a fast shutter speed -- to freeze the motion. So you need plenty of light or a "fast" lens. A fast lens is one in which the aperture opens further to let in more of light. The smaller the number of the maximum aperture, the faster the lens, so a 28-105mm f/3.5-4.5 lens is "faster" than a 28-105mm f/4.0-5.6 lens. But usually, faster lenses cost more.
For the settings on the camera, the Rebel K2 has a Sports image mode (silhouette of a runner) on the control dial which should get you appropriate settings for most action shots.
If you want to set the shutter speed yourself use the Tv mode, and with a fixed shutter speed, the camera will set the correct aperture. Watch in the viewfinder -- if the aperture value is flashing, it means the shot will be underexposed. You will have to select a slower shutter speed.
Another way to get action shots with limited light or a "slower" lens is to use film with higher ISO/ASA. ISO 100 film is good for daylight shots, but for inside shots or evening shots, use ISO 400 film. Higher ISO film is "grainier", so enlargements will show less detail.
May 07, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Shutter speed
keep the focus mode on AF-C for continous focusing
if you get the same promblem mail on - mworld22@gmail.com
Oct 10, 2007 | Nikon D40x Digital Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
H1 - blurry/soft pictures
I'm afraid this is more a learning curve in general photography :-) I know I also fell into that pit, after so many years of 35mm usage!, by believing at first that "digital" can do it all, well it can't fool general laws of photography/optics :-) .. once one has mastered that, things have a tendency to go a lot smoother :-)
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Canon T90 35mm SLR Camera Logo
939 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
