Back to:
Tags:
NEC MultiSpin ND-1100A  DVD+RW Burner
Recording speed on NEC DVD+RW ND-1100A DELL OEM
By Rachel007 - usenet poster
I have a Dell desktop with an NEC DVD+RW ND-1100A OEM burner.
It has been flashed with firmware (from Dell) version 10 GE long time ago.
Burning Maxwell 4x DVD+R OK.
Recently I bought some 8x Maxwell DVD+R.
The burning speed was downgraded back to 2.4x using Nero 6.
Is there a firmware that can fix this problem?
I'm not looking for a firemware that can make this burner to
burn the DVD as 8x, just not downgraded to 2.4x.
TIA
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Riddle
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It works great.
Thanks a lot.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on recording speed on NEC DVD+RW ND-1100A DELL OEM:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
The Herrie firmware for the 1100 (actually a hack of the 1300
firmware, with "unguaranteed" DVD-R support added to the 1100
Some 1100 drives may handle -R to a degree using this, but the main
reason is to have a single root firmware , and since the 1300 is
little more than the -R capable version of the 1100 abd was more up to
date, it was logical...
The herrie firmware uses MCC002 @ 4x as the default strategy for
unidentified media (+R)
Actually, if you have moved from Maxell 4x to Maxell 8x and they have
similar codes, using
To switch the 8x media to the code of the 4x may help, as there is
usually good compatibility.
Of course, if the new media is MCC003 and is not added by this
firmware, MCC002 is probably about as good as you can get as a default
strategy for it.
With some of the old drives now, it is getting to the time when you
have to kludge it or scrap it, especially looking at the current
prices ... I can remember paying more than that for a CD-ROM.
I may be dozzzy, but take the ZZZ's out to mail me
# - 2x2x24 CD-RW troubles
If you drop a cactus, don't try to catch it!
Thank You!
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
it has been acting strange for a while now it refuses to...
CD and DVD Burners
Hy, I have been using an LG DVD recorder DRT389H to record...
CD and DVD Burners
I have the video burner but not the camcorder and wanted...
CD and DVD Burners
It stopps for a couple of minuts then its start burning...
NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
My Nec ND-1100A DVD+rw will read discs, but will not write...
Loading problems.
Repair Service
Find CD and DVD Burner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
