The right hand blinker stays on at all times even when the key is removed..right hand window does not work
SOURCE: 96 Honda Accord ignition Key problem
I might try checking with the dealer for a recall on this one
SOURCE: Can't remove key from ignition for '00 honda accord @ park positi
push key in turn on and off push key in work switch off and on .if dont release you probably going to have to take out the ignition switch. make sure your car is all the way in park.
SOURCE: 1998 honda accord won't start
He may have locked up the pin sequence. You might need to buy a new switch not that exspensive. Stay away from the dealership or it will be.
SOURCE: 2005 Honda Accord Front Bumper cover replacement
easy there is a screw on both sides were bumper and fender meet just pop back fender liner its a phillips head. Then pop hood remove clips on black trim infont of radiator. Underside where bumper goes under car remove those clips and 10mm bolts after all is removed bumper just pulls off ...... may have to give it a hard **** a few times but it will come off. Should only take 15-20min to remove if its your first time
SOURCE: 2005 Honda Accord 4cyl cruise control does not work
check all your fuses first then take a look at the brake switch and there is a criuse cancel switch also, i think there may be a problem with the switch,even if the cancel switch was bad i think the power would still stay on but cruise would just stop and power would stay on. check fuses and switches anyway to be sure then take a look at the power switch.
