Question about RCA F36649 36" TV
Sudden channel changing,flipping off and on and channel searching
I have an rca tv. model number 27V412T. all of a sudden the channels started changing by itself and flipping off and on. and then started doing a channel search. i can not stop the tv from doing either of the three things. i have the tv. hooked up to a DVR cable box. i have disconnected the cable box and is currently using just a cable line from the wall. i have tryed to unplug the tv for hours in hopes that that would reset the tv but nothing has worked. the year on the label says 2005. the picture quality is perfert.what can i do to fix this problem. this has never happened.
  • patty_carter Feb 28, 2009
    LOST SOME OF THE CHANNELS ON MY RCA F36649
  • gbreuer Apr 11, 2009
    I have the same problem but when I turn it on it makes a popping sound and automatically shuts off.
    Top Expert:
  • RCA Master
  • 74,871 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Apr 21, 2017
SOURCE: channel constantly searching
#1 resolder cpu oscillator crystal #2 replace eeprom ic. #3 go to service menu set parameter "07" to "00" try one of these steps one at a time.
Posted on Jun 16, 2007
  • 6 Answers
SOURCE: TV contantly searching
the keyboard has bad tact switches or the infrared detector has some issues. you can unsolder the keybard switches one at a time, or you can replace the whole keyboard with some of these models
Posted on Aug 09, 2007
likha
  • 790 Answers
SOURCE: RCA 27V412T
ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
Posted on Oct 01, 2007
pantywaste33
  • 9 Answers
SOURCE: powers on and off my itself. Changes channels by itself
i had the same problem. i opened the t.v. took out the circuit board to the buttons and broke off the little resistor things to all the buttons. JUST BE CAREFUL NOT TO BREAK THE ONES LEADING TO THE IR LIGHT. if you can find another button board thatd be a better fix. let me know if you do please. anyway put it back together and use the remote from now on and it wont turn itself off anymore. my guess is one of the buttons shorted out or something.
Posted on Apr 20, 2009
bhatgiri73
  • 106 Answers
SOURCE: RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Posted on Mar 06, 2010
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Dec 29, 2012 | RCA 27V520T 27" TV
I cant figure out how to do channel search on my tv
What is the model number to your RCA TV?
Sep 02, 2012 | RCA Televison & Video
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
Dec 29, 2008 | Televison & Video
Clicker limits
rca is known for needing new solder jobs and mostly in the tuner area and power section
so it is most likely the the tuner section and probably the power section should get the new solder job done or the tv will start to have a life of its own!
I have a rca 27v412t that started the same stuff but I resoldered and it lasted about 7 months before I had to do it again
and if after that it don't recieve certain frequency's it may need a new IR sensor and possibly a crystal and EEPROM chip as well
electech
Oct 22, 2008 | RCA 32F531T 32" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
RCA 27V412T
I repair these for a living and usually this is caused by the "tact switches" (buttons essentially) on the main pcb. This can be fixed easily by someone who is familiar with working with soldering small parts by changing the switches. The problem is most service shops must charge $60-$100 for bench time on a repair like this which is hard to spend with the replacement cost being so low on this product.
Nov 23, 2007 | Televison & Video
RCA 27V412T
Oct 01, 2007 | RCA F27669 TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
RCA F36649 36" TV Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
