Question about Maytag Neptune MAH5500B Front Load Washer
Lock light doesn't go on, won't fill, metal rubbing sound
I started a load and it was working fine, went back later and it had not even gone through a spin cycle. I put it on several different settings and it will drain, but does not spin. The lock light does not go on and I understand that that would keep it from spinning, but what is keeping it from filling again? As I was listening to the machine at start up, it sounds kind of like metal rubbing against metal. I am not positive though. What do I do?
    President:
  • Maytag Master
  • 2,651 Answers
Thins sounds like a bad control board and wax motor issue, comon for this machine prbably about $300 for you to repair ,closer to $500 for aservice co. however, you say oyou hear a metal on metal rubbing thisi a sign of a more serious problem of rear bearing NOt worth cost of repair.. one way to tell the rear bearing is to open the washer door and grab the inner basket, try to lift it up you should have no movement iff correct. ifyour able to lift teh inner tuban inch or so, independently of the machine, i would venture to say oyou need a rear bearing// i mean new machine!!!!
Posted on Mar 01, 2009
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
2006 chevy colorado out of the blue will not start. just makes clicking sound. Started it drove out of garage shut it off. Went back out 5 minutes later won't start. Clock even reset.
Sounds like a bad battery. A number of chain auto parts stores will check it and your charging system free. Before that, if your battery has removable caps, check the water level, if it's down, fill to the bottom of the fill rings and charge the battery, if you have a battery hydrometer, all the cells should have about the same charge level, if one or more show a lot lower than the others, battery is probably bad. Hope this helps.
Jul 29, 2012 | 2006 Chevrolet Colorado
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Just shut off the care returned 2 hours later no go got a boost went for a drive left the car running for awhile than it start to get like it was going to stall went on g=for a littlwe while than died....
Hi your problem sounds like the battery is gone and won`t take a charge. When your engine is running the alternator is supplying the electrical power to run the car ( and normally charging the
battery as well )
Even though it seems strange for the battery to go suddenly, it does happen.
How old is the bat. Most last about 5 years with normal driving ( batterys last longer if the car is used every day )
Anyway i hope i have been of some help to you.
John (south Wales UK )
Jul 05, 2011 | 1995 Honda Civic
I have a 2006 Dodge Charger. Went out yesterday, car started fine. Got home and stooped at my mailbox, when I went to start the car it wouldn't start. I did notice the lights on the dash would go dim...
I'd start with a battery first. Sounds like the battery has 1 or more dead cells in it. the battery may have all the volts you could want but if it doesn't have the proper amperage it won't crank the motor. You can have the battery load tested for free at Auto Zone or Advance Auto. A simple down and dirty test would be to disconnect the Positive cable and jump the vehicle by connecting directly to that and a good ground on the block. The motor should turn over as long as the vehicle you use as a jump has the proper amperage in it's battery. If the vehicle starts then it is the battery, if it doesn't then you need to look at the starter and other components.
Jun 26, 2011 | 2006 Dodge Charger
Started up this morning fine went and did not start at all later.
remove and, clean your battery cable clamps then retighten and, test.
If your battery is too discharged "jump" it using jumper cables and, another car.
Apr 25, 2010 | 1996 Chrysler Cirrus
WON'T START
my 2006 pt cruiser won"t start. the light do come on but it will not turn over just a clicking sound. i drove it for about an hour then went back to it 30 mins later and it didn"t start. just clicking sound.
Sep 21, 2008 | 2006 Chrysler PT Cruiser
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
