Question about Lexmark E120n Laser Printer
I replaced the toner cart. and now it is only printing 1/2 page
I have put in two NEW toner cart. and it still will only print 1/2 of the page...
  • 4 Answers
Try reseating the toner cartridge, several times if necessary. And make sure the front door is solidly closed.
Posted on Jul 29, 2009
  • 54 Answers
Wrong Driver for your printer. Go to site and get an update
Posted on Feb 27, 2009
Printer only prints out blank pages, toner is full
Dear
It was not mentioned last maintenance job taken on printer. however following are the causes for blank print.
1- The cart. may refilled and not aligned properly (may be toner cart or drum unit, if dual component)
2- bad contact points of the carts. and that of printer base.(may be contaminated or dirty)
3- faulty HVPS?SMPS
4- Harness if any check all high voltage contact points. including transfer roller.
Thanks.
Feb 24, 2015 | Office Equipment & Supplies
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Jan 28, 2014 | Xerox Phaser 6360 Laser Printer
All toner cart's replaced, new toner heads about 1000 pages ago, new waste tray. Printing colors ok but anything with black in it comes out blotchy or faded.
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
Feb 23, 2010 | Minolta magicolor 7300 Laser Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
Copies are coming out with a faded or blank patch in the centre of the page
Check the toner cart and the drum is it old/new is the toner cart properly installed. Is the LASER glass clean it should be protect by a cover ensure machine is off when checking and cleaning the LASER **** glass. Also check if you can print out a machine developed document such toner/pages printed document to see if this problem is related to the scanner or the drum/toner/LASER, if these document print out clan then the problem is with the scanner
Aug 09, 2009 | Canon PC-940 Black and White Copier
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Lexmark E120n Laser Printer Logo
209 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
