Question about Toshiba 50A60 50" Rear Projection Television
Picture seems darker or less intense light
Everything works just seems darker, could the bulb or some internal parts need cleaning. HOW DO YOU DO THIS?
  • dlhunter50 Mar 26, 2009
    Picture is dark on my Toshiba Model 50A60. Is there anything to do to make it brighter
  • 26 Answers
You will need to post tv brand and model number
Posted on Feb 27, 2009
Why has the picture on my samsung 62 inch dlp been getting increasingly darker
Projection bulbs provide a high-intensity light. Most have an approximate 2000 hour life. This can vary greatly depending upon factors such as how often you turn it on and off and how often and how well you clean the filters. As the bulb begins to reach its life expectancy, it will start to get dimmer. A 2000 hour hour bulb, if it reaches that time frame, is expected to be putting out 50% (half) of the brightness that it did when new. It may simply be time for a new projection bulb.
Sep 03, 2014 | Televison & Video
The picture seems to be getting darker. Its not as bright and sharp as it used to be. Its about 9 years old but has not been used very much. Might it need a new bulb or something? 57HX81 Proj TV Color...
simple: remove back cover and locate the three large black lens you will see top and dead center, clean them with either a lens cloth or a paper towel with glass cleaner----they are the light source for your picture and should be cleaned once a year---as they get dusty the picture gets darker and duller looking.\\
SD TECH
Apr 12, 2011 | Toshiba 57H81 57" Rear Projection...
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture darker around the edges
okay okay sir
every thing that u ve done till naow is ok
follow me
first chek the connections
if all the connections are cheked try
toend me ur model number its locate here and i will give u the full help of ur product but dont rate my help yet till i tell u that am finished okay??d4d39a7.jpg
Aug 17, 2008 | Philips 62PL9774 62 in. HDTV LCD...
Optical Engine in a Mits WD-52527
You have to be careful when replacing the projection bulb assembly. Don't aways look for the cheapest as they are rip-offs that do not last long and are not as bright. Dont buy OEM "compatible" only OEM originals. Call Mits Customer Service for advice
Apr 26, 2008 | Mitsubishi WD52527 52" Projection HDTV
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Toshiba 50A60 50" Rear Projection Television Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
