Question about Xerox WorkCentre Pro 765 Laser Printer
Are one touch dialing board not working
Are one touch dialing board is programmed however when we try to fax something using those buttons the fax never gets to that location
  • 239 Answers
When sending, try using a analog phone, and dial the number you are calling. Make sure it is the correct number. You might hear someone pick up the phone, or you will get a recording messege. This will tell you if the phone is the correct number you are trying to dial. When you are finished, plug in the phone line back into the correct jack on the fax machine.
Once you hear the dial tone, your phone is working.
If you can send a fax, and the machine does not send it, then the machines fax board might not be working.
There are other questions I like to ask about the phone line. Are you using a adaptor to convert the analog signal to digital? If this is the case then the adaptor may be causing some problems with your faxes.
Good luck.
Posted on Aug 12, 2010
I have a brother intellifax4100e and when ever i touch a button to send a fax dialing from the keys or using a programmed key - the machine beeps three times. I cannot send any faxes and i have tried...
When you get a treble beep it can be an idication that there is a key stuck down. Check every button to make sure it clicks ok. i bet you have one stuck.
Aug 18, 2011 | Office Equipment & Supplies
How do i change programed number
Hello Ms Nelling,
You can change the programmed numbers by simply programming new numbers on the saved position.
Press the MENU/SET button and select FAX \ Setup Quick Dial and then choose whether you want to program a speed dial or a one touch button.
If you had previously programmed a 1 touch on button 3, just select that 1-touch and it will ask you if you wish to change the current settings.
Thanks,
Pat
Apr 14, 2011 | Brother IntelliFax-2820 Laser Fax
How do I program a new destination # into my fax?
- Open One-Touch Speed Dialing menu - Press DATA REGISTRATION - Go to 2. Tel REGISTRATION - Press SET > 1.1 - Touch SPD DIAL - Specify which button # you want to program on LCD (select up and down button) and press SET - Enter telephone number and press SET - Enter a name and press SET - Press SET to confirm. - Press STOP to return to standby.
Feb 28, 2011 | Canon LaserClass 9000L Plain Paper Fax
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Memory dial
Press the Menu button
Then go 2.Fax, then press Set
Scroll through to 3.Set Quick Dial and press Set
You will then have the option of One Touch or Speed Dials
Once you have selected the one touch. Simply hit the one touch button you which to program. Then program in the name and number.
Jan 25, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
KEY PAD ON FAX MACHINE WON'T WORK
Have you programmed the  'rapid' (one touch) buttons or the speed dial numbers? (print a report of stored numbers to be sure)
Is machine set to fax mode?
Oct 15, 2007 | Brother IntelliFAX 4100 Laser Fax
Xerox WorkCentre Pro 765 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
