Question about GoVideo Go Video DVD/VCR Combo
DVD won't load classifys all discs as bad
VCR works well but has speck on the screen at slow speeds
  • 10,594 Answers
To correct specks on screen while playback of VHS, please adjust Tracking control.
Regarding No Disc issue, please clean optical lens with CD Cleaner or take off top cover and clean it with good quality cotton bud.
Posted on Feb 27, 2009
  • 916 Answers
If the dvd is classifying all discs as bad you will need to clean the lens. If it still gives you the error take off the top and make sure the lens in the dvd player is in the correct position.
    President:
  • 2,653 Answers
Have you tried cleaning the heads with a VCR head cleaner tape?
MY DVD PLAYER WON'T LOAD ANY DVD
Either a problem in the mechanism or the motor is bad, not much else can cause this.
If a moderately priced unit replace it and do not try to repair it.
Apr 27, 2012 | Televison & Video
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
The vcr stopped working, tape goes in but won 't work. the dvd stills works.
most likely a mechanical issue , look inside for anything laying inside the VCR section.
a piece of a label or a toy etc. if all looks well it could be a bad sensor , bad (dirty)mode switch
or sinply a jammed gear or arm.
a good way to check the VCR section is to turn the loading motor and see that it moves correctly
hope this helps
Dec 17, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
DVD won't play
Its Sounds as if your DVD went kaput this tends to be a problem with most combination players usually the VCR goes first also you may need to run a cleaning CD made for DVD players maybe that will help.
Apr 03, 2009 | Samsung DVD-V3500 DVD Player/VCR
Will not load some games
I had the same problem with my ps2. I found a solution that might help you. take a Q-tip and dip it in rubbing alcohol or water just intil damp. gently clean the eye and the rest of the disk tray. then dry it the other end of the Q-tip. when the eye dirty with dust or a hair or a small speck of paper or plastic from a disk will slow the ps2 down when loading. hope this helps!
Feb 13, 2009 | Sony PlayStation 2 (PS2) Console
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Bad disc
clean the laser lens first! or you have damage flex ribbon wire. change flex ribbon wire
Aug 22, 2007 | Daewoo DV-6T955B DVD Player/VCR
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
GoVideo Go Video DVD/VCR Combo Logo
78 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
