Question about Mitel 9109-012-001 DIGITAL LINE Phone
"Lock" display on console
I HAVE SX-50 SYSTEM. the extension for one of the hotel rooms sometimes will read "EXT 114 LOCK" on the console. I've changed the phone and cord in the room but problem still exist. Other times, the problem solves it self but only to go back to "Lock". Any suggestions.
  • Mitel Master
  • 2,460 Answers
Lock means lockout. If you've changed out the entire set to the cords, look for something in the wiring to be shorting out. You'll get that indication if you walk into a guest room and take the phone off the hook. It will alarm at the console and lock out.
Carl
Posted on Feb 27, 2009
SX-50 Mitel wake up calls won't go through to rooms. Is there a way to reset or fix this?
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
May 18, 2011 | Mitel 9104-001-000 Power Supply SX-50...
How can i fix lock on mitel sx50 console ?
Lock? Can you elaborate? I hope you've gotten this resolved already.
Mark
Jan 12, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Mitel sx 50.. How to unlock room phone..how to take it off from do not distrub(in room phone)? Thank you so much
Attendant
Oct 13, 2010 | Mitel 9104-001-000 Power Supply SX-50...
I HAVE MITEL SX50 AND THERS ONE EXT THAT IT SHOWS LOCK WHEN I TRY CALLING IT & THAT EXT DON'T HAVE DIAL TONE EITHER. HOW CAN I FIX IT?
The phone is either off hook or the line is shorted out somehow. If it's shorted out, it's likely a jack and you should replace it. I suggest you contact your vendor for assistance.
Aug 04, 2010 | Mitel 9104-001-000 Power Supply SX-50...
The extension is shorted somehow - likely corrosion on the jack. Replace the jack and see if that corrects it.
If it doesn't, contact your vendor for assistance.
Jun 15, 2010 | Mitel 9104-001-000 Power Supply SX-50...
CALLER ID
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model.
http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
Jan 15, 2009 | Uniden 5.8GHz Cordless Phone
Need to add a prefix
First of all you must enter the program mode if you have your manual it will tell you how to do this. If not try this. press the # and on the screen should show command and a flashing number with a question mark. Enter the number 700 and press enter. this will get you in the prefixes. use the next key to scroll until you a a line with no numbers, it may take a little bit depending on how many prefixes are entered. Now then you use the arrow key to get past the first 3 digits that are flashing, enter the number 01 for non toll calls arrow over one more time enter the number to access an outside line commonly 9 then the prefix excatly how it is dialed eg.( 001 01 91800 05). Recap the 001 is what number in the list of approved prefixes. 01 is non toll call. 9 is the access number dialed form the room to get an outside line. 1800 is the first numbers dialed to call a number like 1800DIRECT. 05 is the number of digits dialed including 9. If you have any problems with this email me donnie_rawls2002 at yahoo.com. Hope this helps. I had to do this today at a local hotel and it was a bit confusing in finding the right commands and how to get there.
Dec 23, 2008 | Mitel 9104-001-000 Power Supply SX-50...
Mitel superconsole 1000
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
Aug 23, 2008 | Lands Phones
Lands Phones Logo
578 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
