Question about Creda W120VW Front Load Washer
Washing machine tripping elec's
My washing machine is two years old. I put it on to my normal wash and just before the final spin cycle it tripped the elec's. now everytime i turn it on as soon as it starts to spin the elec's go off. I have checked the motor, brushes, valves, filter, pump and hoses and these are all fine. I also tryed to start a new cycle which started fine, the washing machine filled with water and just before the spin the same problem. also there was a spark inside the drum just before it tripped the elec's. is this something i can fix or do i need a new machine. thanks for your help.
  • armbarqueen Feb 27, 2009
    sorry my washing machine is a beko not a creda. didn't know it would put my question here
    Scholar:
  • 135 Answers
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Sorry.
Posted on Feb 27, 2009
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
My bush washing keeps making my fuse box trip
when I put my machine on to do a washing it blows my fuse box 8 mins into every washing cycle I select, It spins ,drains and rinses ok .So what can it be???????
Jan 22, 2013 | Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Creda W120VW Front Load Washer Logo
246 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
