Question about Archos Computers & Internet
Hi, I have an Archos 605 wifi 4gb .Was working well till put a memory card sandisk schd into it for extra memory and it asked if i wanted to download the contents to the 605.Thinking it was going to download my other files to use on the 605,i pressed yes.Since this, i have lost all my files or their corrupt and dont open,am not able to use the touch screen anymore,all my photos have gone and think i must have lost some of my operating software or it is corrupted. Any ideas??????? Andy
  • acharlesc Feb 27, 2009
    Have tried this,ie reformatting but does not help.
    thanks
    Have tried resetting and formatting through the Pc,without success.
    Brigadier General:
  • 5,158 Answers
Download this utility and format the sandisk
http://www.sandisk.com/Retail/Default.aspx?CatID=135
if there is a reset or way you can reinstall to your pda.. do that after it is formatted
Posted on Feb 27, 2009
    Sergeant:
  • 319 Answers
It sounds like the card may have had corruption on it, or the device itself needs to be reinstalled to factory settings. as far as your information, have you tried to put the card into a PC?
My palm did something similar to this, and it was rectified by resetting it back to factory defaults. hope this helps at all...
  • 19,396 Answers
Check if a copy of your old files is still on the old card , and make a copy of the old card onto a new one using a computer and a card reader.
To make a copy insert old card in card reader
Open the card.
Chose Select all.
Chose copy.
Paste onto a folder in the computer
Insert new card in the card reader (possibly formatted.
Select all files on computer from old card folder.
Paste files onto new card.
If you have formatted both old and new card there will be no way to recover the files.
Here is the card reader ATP All-in-1 ProMax USB 2.0 Memory ...
    Scholar:
  • 165 Answers
Remove the battery for a while and then reinsert it,then remove the memory card for a while and reinsert it.then press the reset button for 10 seconds continuously and it will get reset to work properly.
    Brigadier General:
  • 8,619 Answers
Hi!
Try removing the memory card and then see if the touch screen is working or not. Also try taking the battery out and inserting it after 10 minutes.
  • 916 Answers
Putt a toothpick in the hole on the bottom for 15+ seconds to reset the device and see if you still have the same problem.
Please post the results.
  • 10,594 Answers
Take out memory card and perform RESET to unit and check.
PNY SD 4gb card dose'nt work....
Do you know if your Archos 605 media player supports schd cards? SD and SDHC is not compatible.
So if your Archos 605 is not sdhc compatible no sdhc car will work.
I hope you find this information helpful.
Sep 20, 2009 | PNY 4GB Secure Digital High Capacity...
How do fix my Archos 605 after resettin using factory option
Well If a white screen shows up when you turn it on, select format. Wait for it to finish, then when it asks for a update file, plug it in to the computer and copy the .aos update file to the archos. Don't put it in a folder, just put it the root, (the folder that has the folders for music, video, flash, etc.) Unplug it and the archos should recognize it and proceed with the firmware update.
The Updates can be downloaded here:
for 20GB-160GB
http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
or for the 4GB
http://update.archos.com/5/a605f/a605f_r2.1.04/firmware_a605f.aos
Aug 25, 2009 | Archos 605 WiFi Digital Media Player
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
My archos 605 4gb keeps locking up ....i have to keep pressing the reset button to use it again...why??
Memory inside is fouling and it is going to need to be serviced or if there is a firmware update I'd try that before all else.
Apr 22, 2009 | Archos 605 Digital Media Player
Archos 605 wifi 160GB
I would suggest that you buy a external USB card reader, you should be able to pick one up quite cheaply and see if that works ?
Jun 18, 2008 | Archos 605 Wifi Portable Multimedia Player
Archos 605 wifi
I get it why people have to go around asking experts directly(your not the only one).
Can you tell me the connectors behind your television
Jun 01, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 parental code
i got the same problem, somebody help us please?
Mar 29, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
27 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
