Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Broil Element will not heat up on Kenmore Model 911.9330192
I have already checked the continuity of the element and it checks ok. What else could be the problem and how do I check it
There is a button on stove somewhere i dont know where its located please advise
Posted on Feb 27, 2009
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
Broil does not work
the broil element
Aug 05, 2014 | Kenmore Ovens
Broiler wont work on maytag oven
the broil element
Apr 27, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Broiler turns to pre heatworks oven doesnt heat when temp
the broil element
Apr 15, 2014 | Kenmore Ovens
Broiler won't work
the broil element
Apr 14, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
Broiler wont light
the broil element
Mar 17, 2014 | Kenmore Ovens
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Mar 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electric range 790.91011200 When set in broil mode the broil element does not get hot but the bake element does. Should I replace the broil element?
yes. you can do a simple continuity test to be sure (on the broil) element, but you're gonna spend at least 20 dollars on a volt/ohm meter. if you have one already, you're in luck. just remove the element and test the prongs for continuity (usually setting RX1). more than likely the element just needs to be replaced
Jul 07, 2011 | Kenmore Kitchen Ranges
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
114 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
