Question about Kirby Heritage II Vacuum
Why does my Hertiage II vacuum seem to be getting no power although it is plugged into the electrical socket? Does the vacuum have a motor that might br blown?
  • 8 Answers
Check to see if there are any breaks in the cord, like any of the insulation missing.
Also unplug it and feel along the cord for any unusual lumps.
Posted on Feb 27, 2009
Central vacuum won't turn off when hose removed from wall socket
There is a switch somewhere close to where you plug in the hose. Check and see if the switch is stuck in the down position. If so, it will either need to be replaced or cleaned to allow the switch to raise to the off position.
Semper Fi,
Z
Aug 03, 2017 | Vacuums
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
My cord has to be pushed in to socket and giggled to get the vacuum to have power? Any suggestions?
You might want to remove the electric plug from the wall and spread the prongs just a little bit, it sounds like the plug might be loose in the wall socket.....try it in another wall socket and see if the problem continues to exist...generally it you get the same result from similar wall sockets...you may have looseness in the electrical plug...meaning that you might have been unplugging the cord by grabbing the cord and snatching versus unplugging with the plug itself. Hope this helps.
Sep 25, 2013 | Electrolux Guardian Bagged Canister Vacuum
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
Lost Power Cord during Move. Can we replace it?
sure you can eve replace it by your self buy a long 3 meters thick electric wire buy a plug socket for it and open the screws of the vacuum cleaner face at the back of power plug socket you will find tow screws install the pair of wires on the pair of socket
test the cleaner
then assemble back
May 22, 2011 | Vacuums
Vacuum won't turn on when plugged in and switch is turned on
The easy answer to this problem is you need a new cord. Any fit all 20 to 35 foot two wire cord will work. However, you will need to take disassemble the almost the entire vacuum to test the current cord to see if it is bad. There are a lot of pieces to take off to get to the inside of the vacuum where the cord enters from the back. You could also have a bad motor.
Nov 18, 2009 | Hoover U6311-930 Power Drive Bagged...
My Vacuumm kirby hertiage made a funny noise and started to smoke and doesn't work.
Remove the cover and change the belt it may have got a rock stuck in the beater bar(brush)
Sep 12, 2009 | Kirby Heritage II Vacuum
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Vacuums Logo
108 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
