Question about Polaroid T730 Digital Camera
Card protection on wii not take pictures
How do you get card protection off so I can take picture's
  • My reply is May 11, 2010
    Which type and make of card are you using?
  • 653 Answers
I assume you mean the card protection on the SD card??? Turn off the camera, pop out the SD card, slide the little switch on the side of the SD card from locked to unlocked, re-insert the card the way it came out, and turn the camera back on. If it still doesn't work, take thed batteries out, reinsert them, then turn it on again. It should be ready now to record onto the external memory. If it still doesn't, get the manual out and check on transferring fiels from internal to external memory.
Posted on Feb 27, 2009
  • Fahr Quad Mar 13, 2009
    So how did that work out???
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
My brother put my camera SD card in the wii and now when I take pictures it says card protected.
These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
If that isn't the problem, then perhaps the Wii has given the card an incompatible format. Try formatting the card. There is a function in the camera menus to do this. This will erase anything on the card, but it appears that you can't access it anyway.
Nov 08, 2010 | Digital Concepts Digital Camera
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
Press MENU to enter the menu. Select the SETUP menu (the wrench icon). Select Protect (the key icon). Protected pictures are indicated by a little key icon in the upper-left corner of the picture. Navigate to the protected ones and press up/down to unprotect.
Or is the entire card protected? SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 17, 2010 | Nikon COOLPIX L18 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Nov 12, 2009 | Fuji FinePix J10 Digital Camera
MY a550 polaroid camera is saying card protected on the screen
When you take the card out, you are storing the pictures on the camera's extremely small internal memory. Is the slide switch on the side of the card in the unlocked position?
Sep 12, 2009 | Ricoh Caplio G3 Digital Camera
How do i sync my remotes with my nintendo wii, four blue lights flashing but not working with picture on screen, cannot get off first screen when wii turns on. cheers
You need to press the red button under the protection cap for the SD card reader AT THE SAME TIME AS the one under the battery protector on the remote. Sometimes, it takes more than one try to get it to work.
Hope this helps,
Aug 02, 2009 | Nintendo Wii Console
Saving pictures
The camera has a very limited storage space on itself. It probably isnt saving the pictures on the card because the card is write protected (probably on accident)
just pull out the card and on it is a tiny little switch. just push that into the next position and it is no longer write protected. the write protection is there to prevent you from losing your photos, to put more photos on it you will have to deactive the protection with that switch, its usually white colored
Jun 28, 2008 | Polaroid A515 Digital Camera
Polaroid T730 Digital Camera Logo
94 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
