Question about HP LaserJet 2100 Printer
Will not print lines like this _____
We have a Hp 2100 TN and it has stared to not print the line like ____ it will print all the other word & numbers but not the lines. Can someone help me or give me any sugestions
  • hharr Feb 27, 2009
    I did that any other sujestions? Thanks
    Problem Solver:
  • 6 Answers
Try reinstalling the driver, you can get updated drivers from HP
Posted on Feb 27, 2009
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
Jan 22, 2013 | HP LaserJet 2420 Printer
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
I got a new computer but an old printer and I need the driver for it. It's a Hp officejet 2100 tn. I worried I'm going to download the wrong one and get virus's.
All versions of windows since Win XP have had the driver for the Laserjet 2100 built in. When you connect your printer to the computer and reboot it should say 'found new hardware' and load the correct driver automatically.
Sep 23, 2011 | HP LaserJet 2100 Printer
Hi, my printer is printing a test page but it's not clear at the left side of my page.what could be the cause of this problem?it's hp laserjet 2100/m/tn
This may be one of several things.
When you rub your finger over the unclear parts, does the image come off and feel grainy.
If so your fuser unit is not fusing the image corectly.
Have you tried another drum unit in the machine, it may be that the problem is on the drum unit and that the image is not transferd corectly.
Feb 10, 2011 | HP LaserJet 2100 Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Black shadow line appears on printed documents. Tried to clean but still appears
Print quality issues of this type are almost always coming from the toner cartridge. Try swapping out the cartridge. Even with a used one just as a test to see if the line goes away. 90% or better chance that changing the toner cartridge will fix this.
Good Luck
Dec 30, 2009 | HP LaserJet 2100 Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
I hsve no lines HP 2100TN
Are you printing an Excel spreadsheet? If so, check the SHEET TAB of the PAGE SETUP menu in Excel and make sure that PRINT GRIDLINES is checked on.
Feb 27, 2009 | HP LaserJet 2100 Printer
Printer is offline the hole office they can't print can your please help guys please
Is there an Ethernet cable plugged directly into it or does it connect to a computer?
Does the printer show ON-LINE or OFF-LINE on the display?
Oct 14, 2008 | HP LaserJet 2100 Printer
Line going through the printed graphic picture
If it is a constant lines and they are 5 inches apart it will most likely be a worn fuser. The only solution is to replace the worn fuser.
The fuser is the roller group that heat the toner onto the paper.
Nov 01, 2007 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
Ben Johnson
