Question about Microsoft Xbox 360 Console
Xbox wont turn on
It wont turn on at all, no matter if I press the button or use the controller
  • 2 more comments
  • Anonymous Feb 27, 2009
    i have the same problem with my xbox!
    xbox wil not turn on no lights on the x box at all but orenge light on power supply box
  • Anonymous Feb 28, 2009
    YEP NOW I HAVE THE SAME PROBLEM TOO
  • copley May 11, 2010
    do you have a power light showing on the power supply? should be a little orange one on one end...
    Novelist:
  • 174 Answers
Try pulling out the power supply from the back of the 360 and giving it a blow to get any dust off, when you put it back in give it a good shove and see if that helps.
if not then try a different power supply on your console and if it still does not work then your 360 needs a repair. we can repair this for you at www.fixmyconsole.co.uk
Posted on Mar 01, 2009
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
When i try to turn on the xbox controller it wont turn on it will just keep blinking. i have tried changing the batteries and turning the system on and off. what do i do?
You have to sync it. To do this you need to Press and and hold a tiny button in the front of the xbox next to the sd card slot for about 2 seconds. Then right afterward press a tiny button located on the top of the xbox controller. Its located next to the battery pack.
Please rate.
Dec 29, 2010 | Microsoft Xbox 360 Controller
Controller will turn xbox on but does not sync what do i do?
There is a round button on the front of the controller and the console. Press one then the other, the order shouldn't matter. Press them within 10 seconds of each other. After a few seconds, the console should recognize the controller. On the controller, this button is between the triggers and on the console, it is between the memory card slots and the power button.
Oct 04, 2010 | Microsoft Xbox 360 Console
Xbox controller
need more info if its just the controller that wont turn on get a new one or replace batteries if it wont connect to consol theres a small button at the top press this along with an equillyh sized button on the consoll beside the power button gold th controller toward the power button for a few seconds
May 15, 2010 | Microsoft Xbox 360 Console
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
Well my controller wont start up my xbox360 i took the hard drive to a friends house and a controller for a day than when i got back i got back on my 360 and it wont start up ?
press the button on the top of the wireless controller while its on and turn on your xbox. then press the button directly next to the power button
Feb 24, 2010 | Microsoft Xbox 360 Wireless Controller
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
