whenever i'm trying to play dvds( irrespective of burned or commercial discs)on my laptop (hp 520) the sound is not coming properly kinda scratchy. However , when i copy the files on to my computer and then try to play them , they are playing absolutely fine. I'm using VLC player as well as in windows media player , and also power dvd. All have the same output .
tried deleting the filters from the registry; still the same issue. Everytime i have to copy all the files on the discs and then i have to play the files on to my comp.
Kindly help
You need to use a sound wire from your dvd player to your motherboard. if you are already using one i would suggest getting a new one.
it would not be a codec problem or the files from your pc would play the same as the dvd ones. you have no direct sound feed wire from your dvd player. it is a little skinny wire with a little flat connection on each end. it will go from your dvd to your motherboard. you need the sound to go through the best possible way and the IDE cabel is not the best way.
all the sources have the same output yes but they do not have the same output.
what filters did you delete and what else did you remove from the registry?
same output, different input,sorry.
i dont think so... after installing k lite codec ; the problem started to happen; i have completely installed the k lite ; but the problem is still there. i guess its some kind of codec issue.
