Question about Sewing Machines
I have a Elna sewing machine. The needle couldn't grap the thread from bobbin. I took the machine in to one sewing repair and he saids that my machine was old. He said that inside the machine, something was broken. The machine was too old and can't gets parts to it.
  • Sewing Machines Master
  • 1,133 Answers
If you are in the USA you could try www.whitesewingcenter.com, he is the Elna guru and may well have parts still. There are plenty of these machines still working; if you check out the Yahoo group called Elna Heirlooms you'll find other owners who often repair their own machines and share knowledge.
Posted on Nov 16, 2011
    Scholar:
  • 69 Answers
If you machine is truly old (over 20-30 years) then you probably have a broken gear and on the elnas the part can be hard to find and if found, expensive to repair.
Posted on Mar 01, 2009
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
Elna 2004 does not pick up bobbin thread Help please Any easy fix
Install a brand new needle. If that doesn't help, the machine is most likely out of time--the needle is arriving at the bobbin at the wrong time to intercept the bobbin thread. Search for sewing machine timing or take it for service.
Mar 20, 2017 | Elna Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
In my old but good elna sewing machine thread got stuck in bobbin case and it is jammed
then you need to get the bobbin case out and clear all thread . if you can not get it then you need to take to a repair shop
Nov 02, 2015 | Elna 2005 Mechanical Sewing Machine
The thread on the needle of my Elna sewing machine wont pick up the thread on the bobbin and bring it up?
try changing the needle
if changing the needle doesn't help then it's possible that the machine
is out of time & needs to be checked at a repair shop
Aug 22, 2012 | Elna Sewing Machines
OK I CAN'T GET THE NEEDLE ON MY ELNA 1010 TOPICK UP THE BOBBIN THREAD WHY
sewing machine shop technican's have special tools to adjust the
timing on sewing machines.
if you do take the machine to be timed, when you get the machine
home,, sew on the machine right then to make sure that it sews
the way it's suppose to,
Jul 31, 2012 | Elna 1010
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
I CANNOT PICK UP THREAD FROM BOBIN TO NEEDLE. I HAVE CORRECT THREAD ON MACHINE AND BOBBIN-BOBIN IS IN CORRECT NEEDLE IS CORRECT. THE MACHINE I HAVE IS THE 3230 ELNA AND it SEEM TO BE SOMETHING WRONG WITH...
* Try to hold the end of the top thread towards to the back of the machine while you turn the hand wheel towards you .* Have the tension on top set to four.
* Check the bobbin tension. It should be set to set to four. This is an equivalent pull with the above tension.
*If this doesn't work the machine will need to be "timed" properly. Your local repairman can help.
Sep 04, 2017 | Elna 3210 Mechanical Sewing Machine
Sewing Machines Logo
156 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
