Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
Whirlpool DU 1050
The dishwasher will not empty the water in the bottom after the cycle
Hi, I bought a brand new Whirlpool Gold GU2275XTVS that had the same problem after I installed it (standing water in the bottom after the cycle--although it would drain out if I pressed the drain/cancel button...not sure if that applies to you). It's less than a month old and still under warranty, so we had a technician come look at it but he couldn't figure it out. I've been searching these appliance repair forums for answers but found none that applied to my specific problem. I'll share what I found in a second, but first here are the most common problems associated with slow/not draining: 1) your air gap (if you have one) is clogged, 2) your drain hose is kinked or clogged, 3) your garbage disposal drain plug was never removed or the disposal drain is clogged, 4) your pump is damaged or doesn't run at all. There are a lot of appliance forum Q&As that address these issues. If you checked each of the above problems and still have the problem--especially if you have a brand new dishwasher and clogs should not be an issue--then read on...
I unhooked my drain hose and tried the simple "blow test" (just blow into the hose to see how difficult it is to force any water into your drain/disposal). If there is a lot of water in the hose it will be difficult at first, but after blowing water out it will get progressively easier. I discovered that it wasn't necessarily difficult to blow air through the hose, although oddly it got MORE difficult the harder I tried to blow air through. I then realized that the check valve (keeps drain water from returning to the dishwasher) was inside my drain hose instead of attached to the pump. If you have the same Whirlpool drain hose, the check valve is just past the first elbow of the drain hose where it attaches to the pump. I couldn't see it, but when I stuck my finger around the bend I could feel the valve. What's more, the valve flap was toward me--which means that it was (at least partially) closing off as water tried to drain out of the dishwasher instead of closing off any backflow. It came from the factory like this; luckily it was an easy fix. I simply pushed the valve flap through to the other side of the valve hole. Problem solved--it drains like a champ.
Hope this helps.
Posted on Apr 23, 2009
Did you recently install a garbage disposal??
we did this once and forgot to open the punch out where
the dishwasher attaches.. Voila.. water can't drain,
hope this helps.
Posted on Apr 03, 2009
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
When dishwasher drains the water not all the water is drained. Some stays standing at the bottom and starts getting an odor after awhile. This is a replacement dishwasher in a 35 year old house. How...
It's most likely that the filters in your dishwasher are blocked, the best way to clean them is to remove the filters from the bottom of the dishwasher, place them in the racks and run through the hottest wash cycle. It also helps to have a dishwasher cleaner inside the machine at the same time, these are available from most places that sell the dishwasher powder.
May 15, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
WATER IS LEAKING OUT OF DISHWASHER DURING CYLE
could be one of 2 problems. 1) the rubber gasket seal has a small tear or hole... it doesn't take much. or 2) the door latch is loose or broken
Mar 13, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
597 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
