Question about HP Color LaserJet 3500 Printer
Copy function any copy function in this type of mechine? how to do?
  • 2,229 Answers
This is just a printer. You can't use it as a copier.
Posted on Feb 27, 2009
How to reset error copier mechine estudio 2006
The Toshiba eStudio 350/450 copier is one of the more popular copiers available in the marketplace. It has several features that make copying, printing and faxing easier, such as password protection and customizable settings. There are times, however, when a lost password must be recovered. Toshiba has provided a simple method to recover the password and, if need be, reset the copier settings.
By Daniel Valladares
Resetting a copier to its original settings is a simple way to fix several problems.
Step Make sure the machine is off. While holding down the "0" and "8" buttons on the keypad, turn the copier back on. Keep holding the "0"' and "8" buttons until the copier lets out a long beep. This will activate "Test Mode D."
Step Type in '263' on the keypad and press the green start button. The password should now show up on the copier's screen. At this point, you can type in a new password if you choose to do so.
Step Press 'Set' to set the new password. Turn the machine off, wait fifteen seconds, and then turn it back on.
Step Go to the functions you wish to reset through the main menu and press "Function Clear." If prompted, type in the password. Repeat for any function you wish to reset.
Oct 11, 2017 | Office Equipment & Supplies
Canon IR400 mechine print to black copy
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
TOSHIBA 455 MECHINE HANGS ON COPYING
Clean the 2 registration sensors and the registration clutch. Mostly this is caused by paper dust to the 2 registration sensors. This sensors is easily removed by opening the side cover , you'll see the registration sensors at the lower part of the drum unit. There is only 1 screw holding this. Remove that screw and slide it to remove.
Oct 27, 2014 | Toshiba OEM ESTUDIO455SE 45 PPM...
How to Hard Reset Canon iR6000
press aditional function ,then 17+39 ( 1and 7 same time , 3 and 9 same time) again additional function .and select 95 th option in display (e355 and all ram clear ) press 2 and enter ..within few minitus mechine restart if restartting time just swich of mechine manually and on
Dec 14, 2013 | Canon imageRUNNER 6000 Copier
Ir1024 given error 000
turn onn the mechine press star button of additional function and press 2 then 8 for same time then press star select copier option then function then clear then err then ok restart the mechine it will work
hope soloution help you
Sep 05, 2012 | Canon Office Equipment & Supplies
Canon ir1024 given error 000
Dear Sir, my problem is to get English manual of "Miele Washing Mechine, the function language is written in German, i can not operate it, i wish to request for it's English manual, the model is:...
Welcome to fixya
I have a solution for this
Content
Please check onlinemanuals dot com in order to download a free copy of your needed instructions in several different languages.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Electric Garden
My desktop is black and how can i remove victim of software counterfeiting easy?
Download this file:
When finished, right click the file and choose extract, finish the wizard and open the extracted folder
1. Copy ALL the files inside the "files need to be copied" and Paste it on C:\WINDOWS\System32
2. CLICK ---> start ----> run and type "instexnt install" (without quotations).
doing this, Your Windows Xp Copy Will appear genuine for LOOPHOLES Microsoft
4. restart your computer OR add the registry file "1.reg" to your registry .
You can Install Windows Media Player 11 for Windows XP (I guess you know what it is)
Windows Defender (Protects you from Spyware)
Microsoft Security Essentials (Protects you From Virus)
Microsoft Calculator Plus (Conversion Feature)
*********ALL FOR FREE!!!**************
And many many more! See how you can easily FOOL Microsoft!
** You can use the file "Wga.exe" to clear Microsoft Notifications.
By Gian Franco Briones Dy
free.to.rhyme@live.com
Jan 22, 2010 | Microsoft Windows XP Professional for PC
The cooling function is always on. The dryer will not heat regardless of the mode that it is in Normal/Timed/Manual
hi your mechine will be having a option called reset button by reseting it your mechine program ill be reset and come s to normal state
Aug 24, 2009 | LG Dryers
Canon copier - switching between default setting
You can usually adjust the timer settings via the additional functions screen and select 'timer settings' and within there you can set 'return to standby timer' this will help you. The way to access this mode varies from machine to machine but if you have a key with a head and a star inside it, that will get you into the additional functions screen.
May 17, 2009 | Canon Office Equipment & Supplies
HP Color LaserJet 3500 Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
