Printer says printer not communicating
Printer statement on error is not powered up or not communicating but power is on and it is all installed in usb001 and it tries to install it in lpt 1 what can i do know. it is a konica minolta page pro 1350 w
  • nigalm nigalm May 11, 2010
    did you try reseating the usb cable? or try another usb cable?
  • 54 Answers
Reinstall the drivers or replace your usb cable
Posted on Feb 27, 2009
Photo copier ricoh sc144
SBU Communication Error
  • Connection to SBU cannot be confirmed. (Connection detection error)
  • Cannot communicate with the SBU, or the communication result is abnormal.
  • SBU defective
  • The other side of the communication (BCU, IPU etc.) defective
  • Power/signal harness defective
  1. Turn the power off/on.
  2. Reconnect the power/signal harness.
  3. Replace the following parts:
    • Replace the SBU board.
    • Replace the IPU board.
    • Replace the BCU board.
    • Replace the power/signal harness.
Apr 11, 2016 | Ricoh Office Equipment & Supplies
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Error 1102
Hi
This is a communications error between the cartridges and the machine.
  • Disconnect the printer from power completely and wait for 2 seconds and then connect again.
  • Try printing a test page.
  • Solved?
  • Disconnect again from power.
  • Remove the top cover.Using the carrier belt and gently move the cartridge carrier to the middle.
  • Remove the cartridges,close the cover top and fit the power supply and turn the machine on.
  • Is the error on?
  • Then there must be a hardware problem with your machine if the error returns.
  • Try cleaning the cartridge contacts before installing them again on the machine.
Feb 27, 2012 | Lexmark P4350 All-In-One InkJet Printer
I loaded my Lexmark X6180 printer with the software, and the installation went fine to the finish. But I get a communications error message "cannot communicate." What shall I do to fix?
What is the operating system installed on your computer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 24, 2011 | Lexmark X6180 Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    I got error message E191 wt should i do..?? is this error is a big deal...??
    E191 There is an error in the communication with the high-voltage power supply.
    E191-0000 The data transmission/reception does not end
    normally 500 msec after the most recent
    transmission/reception of data ended normally.
    Replace the high-voltage power supply. Replace the
    DC controller PCB.
    First check the current voltage of your installations.
    Jun 19, 2010 | Canon ImageRUNNER 3570 Copier/Printer
    Lexmark X5470 software rejects generic ink cartridges
    Yes this may be the trick for it.
    Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Jul 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
    1203 error code
    Solution to get rid of error 1203 on printer 926 is
    Disconnect and Reconnect the Printer Power Supply
    1. Unplug the power cord from the wall socket.
    2. Disconnect the power supply from the back of the printer.
    3. Wait 15 seconds.
      Reconnect the power supply to the back of the printer.
    4. Plug the power cord back into the wall socket.
    Try a Known-Good Ink Cartridge in the Printer Replace each affected cartridge in the printer with a known-good cartridge and check to see if the problem is resolved.
    This error comes up because the copper contact of the cartridge is not able to communicate with sensor of the printer.
    Jun 08, 2009 | Dell 924 All-in-One InkJet Printer
    I have a lexmark t644 printer and have an error code of 900.44 any ideas on how to fix this
    1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
    2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
    3. Power the printer back on.
    4. If the printer goes to the Ready status, try printing again.
    5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
      • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
      • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
    Nov 17, 2008 | Lexmark T644 Laser Printer
    Dell printer power button flashes
    no the printer is perfect , but many times this error occurs after changing the cartridges.
    first remove all the external connections from the printer.OFF the printer remove the power plug.hold for a minute.then plug the power cord and then ON the printer ,connect the printer to the computer by USB wire as regular.and then check by giving printouts.if it still shows the same error.
    then try this
    1)right click the my computer icon
    2)click properties and then click hardware n go to device manager.
    3)uninstall all usb ports and then scan for hardware changes
    4)ur pc will detect your printer and ask for printer drivers
    5)re load drivers and your pc will communicate with your printer
    6)for reloding install the cd follow the instructions on the screen and click next
    7)restart when the printer is loded.connect the wires and cords properly.
    thanks.
    Oct 23, 2008 | Dell 924 All-in-One InkJet Printer
    189 people viewed this question
    jasbo
    jasbo
