Question about Basic Remote Vehicle Alarm System
Ineed a wireing print for bulldog remote start unit
  • 344 Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do i get my bulldog seurity rs82b to crank longer
If you are using the "tachless" start option and the unit will not crank long enough to start the vehicle, you might want to opt for using the tach wire set up. When selected, and following the Tach set up, the unit will then crank until the engine is producing the preset RPM programmed into the unit's memory.
My experience with the RS82 is favorable, but every now and then, the tach wire must be used to be more reliable, especially on some older model vehicles. I have no knowledge of being able to add crank time such as DEI units are capable of.
Dec 16, 2014 | Bulldog Vehicle Parts & Accessories
I have a RS114 installed in a Ford F-150.Was
check the fuse on the main red wire on the remote start unit, I have had a couple that are defective, that clip that holds the fuse tight is not tight
Mar 03, 2010 | Bulldog& Remote Alarm System With 1-wire...
I have installed a bulldog security rs82p on a 2004 merc sable. The bypass module used was originally labeled as a model 20402,23402,27402,&29402. This is now the 791 the unit turns on but does NOT...
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
Oct 25, 2009 | Bulldog& Remote Alarm System With 1-wire...
Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
Feb 12, 2009 | DLX 500 Remote Car Starter
No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Jan 09, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Started the car with remote. it ran for a few minutes and then shut down. now nothing seems to work cant start or drive with key
disconnect wires from unit then check all fuses. get car to start with key. then let me nkow year/make/model of car and what bulldog unit you have
Dec 07, 2008 | Remote Starter with Keyless Entry
Basic Remote Vehicle Alarm System Logo
60 people viewed this question
Top Bulldog Vehicle Parts & Accessories Experts
john h
DrBogo
Level 1 Expert
vtec
Are you a Bulldog Vehicle Part and Accessory Expert? Answer questions, earn points and help others
