Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
How to disassemble Mag innovision 19" monitor
How do I disassemble my Mag innovision 19" silver monitor. Nothing at all happens when I turn it on. I'm hoping I can find something obviously burned out when I open it up. A sticker says TCO '03 near top, if that narrows it down further. I've taken out the 4 screws on bottom and tried to pry off the top part with the screen, like some say. No go. Anybody have any ideas?
  • rsuitts Mar 02, 2009
    Thanks! I would have never thought of trying to slide the frame.
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
Posted on Feb 28, 2009
When I turn monitor on, it stays on only 2 seconds, then goes dark. When I turn the monitor on, it lights for another two seconds, then goes dark. It is a MAG Innovision TCO 03 display. Thank you!
It could be two things. 1). The video card is set to a resolution the monitor does not support. 2). The monitor's power supply is bad. You can try to boot into rescue (or "safe") mode, and adjust the video card to a resolution the monitor supports. OR, power supplies usually go bad because capacitors bulge or otherwise go bad. Most monitor power supplies are hard to get, so people typically repair them. If you disassemble the monitor shell, you can see the power supply (where the AC cord goes). You can look at the metallic, cylindrical looking things with minus signs down one side, and if they look bulged on top, you can replace them. You can get replacements at mouser.com.
Mar 30, 2013 | Mag Innovision 19" LCD Flat-Panel Monitor...
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
550 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
