Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Auger wont move after hearing the impellar stiking it.(Snowblower
I have a 824 Toro snowblower. I was out tuning the carb after a float repair and replacement. When running the auger I could hear what I thought was the impellar stiking the auger with every revolution. Sure enough it was. How do I move it the impeller back or is it a problem with the auger. There are two screws that were loose around the pipe that goes into the auger. Now the auger wont move at all, it is not caught on the impellar?
Any ideas? 30cm coming tomorrow!!
  • bnjay Feb 27, 2009
    I did just what you stated but without removing the chute, I could tighten the set screws from the front(yes after the key was off and power cord removed) it has stayed in place and I am now ready for the snow. I also checked the pins and they are in good condition. Thanks again for your advice.
jgwhomeequip
  • 1902 Answers
SOURCE: toro 724 snowblower won't start
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Posted on Feb 09, 2009
  • 52 Answers
SOURCE: i have a older areins snowblower with a tecumshen
whithout the engine running the gov should be trying to full throtle. when started this should tell the carb to supply or restrict fuel/air to compensate for load or the lack of. but to answer your question....yes the gov should be wide open, unrunning.
Posted on Aug 30, 2009
backwoodsctr
  • 169 Answers
SOURCE: engine has seized up on snowblower. replace it?
either replace it or short block it, either way you will be re-newing the heart of your machine..... short blocks are typically less expensive
Posted on Nov 23, 2009
  • 110 Answers
SOURCE: upon starting engine screams then idles down but
SOUNDS LIKE YOUR GOVERNOR LINKAGE IS NOT ADJUSTED RIGHT , OR YOUR THROTTLE SHAFT IN THE CARB IS BINDING.
Posted on Dec 15, 2009
ToolBoxHero
  • 171 Answers
SOURCE: Our HMSK 80-110 electric start
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Posted on Jan 14, 2011
I replaced the auger on my Toro 1800 electric snowblower and now the auger stops as soon as it hit the snow. How do I adjust the auger?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 08, 2017 | Toro Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
HOW DO YOU CHANGE BELTS ON TORO 824 SNOWBLOWER
you have to ssplit the snow blower in half to get to the belts. Its easy but make sure to replace both belts and also check the auger bearing they are known to wear out and the auger belt will not get tight. The bolts are on ether side behind the auger assm
Aug 20, 2009 | Garden
I have a Toro s 200 model 38130 1979 snowblower. it would not prime no suction when bulb pushed. I replaced the diaphragm with a kit diaphragm first to carb etc. along with new needle valve and spring. Now...
snowblower no fuel . pull float bowl from the bottom of carb the bolt you removed from the bottom to take off the float bowl there will be a small hole in it take a needle make sure to clean it out . then clean out where it threads into .
Dec 03, 2008 | Chevrolet C1500 Cars & Trucks
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
282 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
