FixYa.com
Tags:
Vantec CPU Cooling Kit
Question about AThlon 1.2
By M0nica L - usenet poster
I,ve got a Athlon 1.2ghz cpu and a ECS K7S5A mother board. After installing
the board and the cpu I can only get it to run stable at 900.There doesnt
seem to be a lot of adjustments on the board itself and there is a "CPU PnP"
setting in the bios. If I set that to run at 1200 it starts to run hot and
therefore becomes unstable. Has anybody got any ideas how to get this thing
to run at 1200? Do you think a better heatsink and fan will allow it to run
at 1200. Any suggestions are appreciated. Thanks in advance,
Note: @ 900 runs at 55-60 degrees
@ 1200 runs at +75 degrees
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (#).
Version: 6.0.345 / Virus Database: 193 - Release Date: 4/9/2002
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Before going out and buying anything new check to make sure that the power
supply is plugged fully onto the mobo. I had the same problem when I built
my last system and a friend and I were both stumped for about 45 minutes.
We changed out the cpu fan and the temps actually went higher. It was just
plain anal retentiveness that made us recheck all the seatings on the mobo.
Good luck.
Psy
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Les, but some Arctic Silver 3 paste and apply it to the heat sink.
If that does not work get this:
VANTEC CCK-6027D Copper Heatsink and 5500RPM 30CFM Fan. Heat Sink Material:
AL 6063T5 & Copper. Dimension: 58.0 x 64.0 x 64.0 (mm). Recommended For:
IIntel PIII Coppermine(FC-PGA)1.13 GHz and above AMD Thunderbird
has them for $18. I don't work for NewEgg.
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
I don't think you missed any--the only jumpers you can set are keyboard
power-on and clear cmos. The board is supposed to auto-detect the cpu. Make
sure it has properly identified it. You can hit page-up at boot to get a
default setting for the cpu. Otherwise, all you can really change is the
frontside bus speed.
Chris
Solution #4
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
thanks for the reply. On this mother board (K7S5A) is there any other
settings I may have missed or do not know about?
Other than the settings in the bios I cant seem to find any.
Thanks
Solution #5
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
Definitely check that the heat sinc is making good contact with the CPU
before turning it back on. 75C (167F) is way too hot - unless you're
planning to fry some eggs on it. Try using some heat transfer grease on
it or maybe a different CPU cooler. What cooler are you using - I like
the GlobalWin FOP-32 and the Volcano-II for Athlons above 900Mhz.
Good Luck
NRJ
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
