Question about GE WSXH208A Front Load Washer
GE model WCVH6260FWW is leaking from the middle of the front door
When the washer is filling with water, water just as quickly is coming out the bottom of the door in the middle of the door.
    Scholar:
  • 106 Answers
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Washer is displaying no error code however the cycle stopped in the middle. I tried to rerun the load. The dorr locked but it will only buzz. Now the door will not unlock and nothing will male it run. I...
You may have a water valve issue. (leaking water past valve, allowing water to fill to higher than normal level) To unlock, try opening the access door at the bottom left on front of machine and using small hose there, drain water out of machine. If hose is plugged, you may have to unscrew big knob (with filter attached) to drain. When the water level lowers, door should unlock. (if washer is plugged in)
Apr 12, 2011 | LG WM0642H
Door leaks water
funny on these washers they used a piano hinge for the upper and lower hinge often they get bent real easliy and sometimes you have to replace the front panel
Jun 02, 2010 | General Electric WSSH300G Front Load...
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine was working fine, but leaking water from the bottom. took it to a repairman, he said pumpwas stopped up and he replaced it. hooked it up and it fills with water but it will not start, wont...
if the washer machine idetifies the levels of water (ex low middle high) means that pressure switch works
there are two things!!!!
the switch's door is not working or the switch's timer also doesnt work
if the washer machine doesn't idetifies the levels of water does the problem
CHECK ALL THIS AND CHANGE WHAT IS NECESSARY!!!!!
Oct 05, 2009 | Roper RAS6233KQ Top Load Washer
When starting dish washer water comes out at bottom of door about in the middle
You don't list the manufacturer or model number, not its approximate age but there are generally two things that need to be repaired or adjusted when you have a leak.
1.) The door gasket
2.) The door latch ... but if after you close the door and it latches, if it appears to lock tight, replace the gasket.
Good Luck! Please post back here what you find and decide to do, OK?
Apr 17, 2009 | Dishwashers
Leaks badly
Most dish washers do not seal at the bottom, the door lip just sits
in front of the tub lip and does not make a real tight seal like a refrigerator door, so unless water is spraying out the top and sides of the door,I would assume that it is either overflowing,or you are using the wrong detergent and it is just foaming to much inside the washer and going over the lip and dripping on the floor. Once the suds stop getting agitated then turn back to water and don't look like suds.
So if you watch the washer during the cycle and the water s only coming from the bottom it is the water level switch inside on right
in the front,looks like a mushroom, once the washer reaches a certain level of water this switch floats up and shuts off the water to stop it from filling anymore. If this seems to be the case just remove the front bottom kick panel and you should be able to see the switch, watch it when the washer is filling,you can also push up on the little arm and the water should shut off. Post back with any questions.
Apr 16, 2009 | LG LDF6810ST Stainless Steel Built-in...
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
GE WSXH208A Front Load Washer Logo
539 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
