Question about Samsung SGH-D500 Cellular Phone
Water has gone in trough hole where charger pin has to be placed
Little water has gone into my mobile trough hole where charger pin has to be placed for charging.now my phone is off because i am unable to charge it.what should i do
  • 174 Answers
You can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Posted on Apr 04, 2010
GE Side-by-side refrigerator defrost drain trough keeps freezing up. Drain tube is clear and never gets frozen but ice builds ups and overflows into the bottom of the freezer. What is causing this?
Sounds as if the defrosting timer or the heating element has gone out. Since the fridge works without problem off and on I would lean toward the heating element.
Mar 26, 2016 | GE Refrigerators
Sunroof leaks around window and seal
If this Is a factory fitted sunroof then its most likely not the seal, these seals don't stop rain getting in, the sunroof is designed so that the rain does seep in but falls into a little trough around the edge underneath, this trough will have small holes in the corners where small pipes are attached and these pipes run behind the headliner and down the cars pillars to allow the water to run away. The most likely cause is that the holes in the corners of the trough are blocked and the water cannot escape. Open the sun roof and look in at the edges underneath from above and you should see the problem.
Apr 02, 2015 | Cars & Trucks
Dell laptop latitude C640 model pp01L will not charge or boot
1) Check the AC adapter (Charger) to see if it is putting out 20 Volts DC.
Use a multimeter with the Function knob set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
If there is a multiple setting for the Function knob with DC Voltage, set it to the 0 to 50 Volt (DC) scale.
If you do not have one, or access to one, an economical yet reliable multimeter, can be purchased for as little as $10. (Less in some places)
A multitude of stores carry them. An auto parts store is but one example.
Analog or digital doesn't matter.
http://www.laptoppartsnow.com/uhsdfsrzdgir779.html
This is the DC Power Jack. May be labeled as DC IN on the laptop,
http://www.discountelectronics.com/index.php?l=product_detail&p=14640
I want to show you it, and have you look at the cable end, that is coming from the AC adapter (Charger) TO the laptop.
(To the DC Power Jack)
See the 3 pins? Arranged in a triangle? Note the socket holes in the cable end.
The pin that sits all by itself on Top, is the Positive pin.
The two pins down below are Negative, or Ground, pins.
The Positive (Red) probe lead of the multimeter, is inserted into the single socket hole, in the cable end.
The Negative (Black) probe lead can go into any of the two bottom socket holes.
Read very near 20 Volts?
Have an assistant wiggle both cables. First the one from the charger To the laptop, then the one from the charger to the wall receptacle. (Or surge protector, actually)
2) Charger checks out?
Go to the DC Power Jack.
You may wish to skip checking the charger out first, and check the DC Power Jack, if you Know that the charger is good.
Battery removed see if you can wiggle one of those 3 pins around.
Be gentle, use a pencil if available.
ANY perceptible movement means a Problem.
Looking back at the second link above showing the DC Power Jack, note the metal prongs coming down towards the bottom of the jack.
There are 4.
2 on each side.
Note the 3 long pins sticking down towards the back of the jack.
The 4 outside prongs made from the outer case, are used to anchor the jack into place. They go down through holes in the motherboard, and are soldered on the opposite side.
There may be Ground attached to the case through these prongs also.
The two pins sticking down towards the Back of the jack, are also Ground pins. (Negative)
The single pin by itself is Positive.
A) IF, any of the pins wiggle, the jack is broken, and needs to be replaced.
B) IF, the outer shell of the jack wiggles, the jack May just need to be soldered back into place.
(Could also be an indication of more damage than appears to the eye)
Same thing for the single Positive pin solder joint.
Charger checks out, DC Power Jack checks out, the problem may be a bad power sensor chipset.
This chipset senses when the laptop battery needs a full charge, or a trickle charge, or no charge.
This means it also will sense when the laptop is to be run straight off of the charger, and not the battery.
Usually means motherboard replacement, unless you have access to the chip, and means to replace it. (Soldering tools, and technique)
Appreciate it if you would keep me apprised as to what you find.
Post in a Comment.
Regards,
joecoolvette
Jan 23, 2012 | Dell Computers & Internet
Drain trough at rear of fridge freezer constantly full of water . Drain hole appears to be clear. fills up every day
The evaporator fan may be drawing the water back up the drain hole when it comes off defrost. The drain might be trapping itself or the drain trough might not be allowing the water to travel to the drain hole. Another cause could be condensation and not the drain at all. Door seals may not be working properly.
Jul 04, 2009 | Refrigerators
My mobile didn`t charge the battery
it might be the battery you should try using a different charger  and also you should see if any of the pins from phone is damaged you could check it out by looking in the charging hole.
May 30, 2009 | Samsung SGH-X480 Cellular Phone
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Charger socket broken
That little black thing goes into the charger so without it, or something to replace it, you can not charge, unless you somehow found a way to take out the battery and charge it outside of the ds. I would highly recommend sending it back to Nintendo or something like that.
Jan 24, 2009 | Nintendo DS Console
Water appears at the bottom shelf below vegggie draw, but there is no place above it or elsewhere that is the slightest bit wet, no place from which it is dripping or flowing from that is evident. There is...
Hi ,
Maybe this can help (if it is a no-frost type refrigerator )
Try to locate the drain trough, which is located just under the freezer -section panel sepparator ,at the back (in the refrigerator section)
Prey it out ,clean it ,push a flexibile rod in the drain line to unclog then replace the drain trough.
Or look for a drain hole just above the veggie shelfs on the elevated part,Try to unclog it with a proper tool.
If neccessary mail me jvclean@gmail.com
Mar 06, 2008 | Refrigerators
Samsung SGH-D500 Cellular Phone Logo
177 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
