Question about Kenmore 47783 Electric Single Oven
How to connect the Wall oven to a 230 Volt connection.
I need to connect the mentioned wall oven to a 230 volt conncetion and using a step doen transformer apply a 110 volt connection to light / bulb etc (items running on 110 / 120 volt).
    Sergeant:
    Champion:
  • 338 Answers
The oven wont work properly..
Posted on Feb 28, 2009
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
How can find a electrical wire in closed wall that not connected
If you have access to one end of power cord then its possible to
trace the wire.
You will need Circut alert tester ( this can be found in your local hardware store or electricien) and small 6 or 9 volt batterie.
Plug the batterie to the end of the wire you have access.
(Make sure its not connect to anything.)
Take your tester pass it over the wall or ceiling.
You will here biping sound when it find the 6 volt current.
Then follow the sound up to the end.
(Sughgestion: Used a certified electricien their have all the tools
Sep 11, 2014 | Ovens
Are wall ovens 120 or 240 volt?
the name plate on the unit should have voltage and current info along with model number of said unit
Nov 17, 2012 | GE Profile JTP18 Electric Single Oven
I have an in wall oven and it is beeping and showing f10
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^&^y
Feb 11, 2010 | Kenmore 30169 Electric Single Oven
F10 fault on tappan range model tef351ewd
Sep 20, 2009 | Tappan 30IN ELEC IGNa Oven
Code F10
Sep 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Recieving a F10 message
Jun 27, 2009 | Kenmore 47782 / 47784 / 47789 Electric...
F10 error
$%^&yt
Mar 30, 2009 | Kenmore 47712 / 47714 / 47719 Electric...
The oven keeps beeping and giving a code of F10
Dec 14, 2008 | Kenmore 47783 Electric Single Oven
F10 error and keeps beeping
Dec 02, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore 47783 Electric Single Oven Logo
317 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
