Question about Dryers
NO HIGH HEAT,MEDIUM SEEMS TO WORK - Dryers
  • brbstan Feb 27, 2009
    Thanx for getting back so prompt. I think it is fixed. The vent hose was almost completly full of lint. After a thorough cleaning so far so good.
  • Rob
    Rob May 11, 2010
    Is there a "low" heat setting, too? Sounds like the circuitry that applies voltage to the heating coils is bad. Is the heat setting controlled by a knob or by touch-buttons?
  • 463 Answers
Yessir! That will indeed decrease the efficiency of the system! Take care.
Posted on Feb 27, 2009
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Amana 80sse furnace fire up work for about 10 min. It goes in lockout and inducer motor stay on
Robert, that is a typical indication of the furnace cycling on its high temperature switch. Look for a dirty filter, return air blockage or any other thing that would cause air flow restriction across the heat exchanger. If nothing else is evident, possibly attempt changing the heating speed to medium low or medium high for heat to improve air flow. But if it worked with no changes prior to this problem, it has to be lack of air flow that is causing the issue.
Dec 15, 2015 | Amana GMH81405DN 140,000 BTU 80% Gas...
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Dryer not heating properly
What is the model number of the unit?
Nov 17, 2012 | Dryers
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
There is no difference in drying between medium and high setting.
You only need a certain amount of heat and air to evaporate a given amount of water. If you don't notice any difference, use the medium setting. You would notice a difference with a larger load.
Feb 20, 2009 | KitchenAid Dryers
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
Top Dryers Experts
