Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Versalik 32y stops working after upload MS Service pack 3
My internet works fine if I uninstall serice pack 3. However when I install serice pack 3 it stops working. Actually the model works fine because if I hook up th modem to my laptop it connects to the net
  • jake_gross Apr 01, 2009
    I tried to install service pack 3, it stopped installing half way through, I had to cancel the install, now I can't connect to the internet on that computer
    Problem Solver:
  • 18 Answers
Howdy,
Try reinstalling SP3. Go to this page: http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
Disregard where it says DO NOT CLICK DOWNLOAD IF YOU ARE UPDATING JUST ONE COMPUTER. You need this download since you cannot get online to update. Download the WindowsXP-KB936929-SP3-x86-ENU.exe file. Be sure to select "Save File" to your desktop. Then transfer it a USB flash drive or a CD and take it to the disabled machine and run it. You can run it right from the USB or CD. It will install SP3 for you and hopefully solve all your problems.Good Luck.
J
Posted on Jun 02, 2009
Dell studio one touch screen is not working
DO NOT install Dell Touchscreen driver as it does not work with MS Touch Pack
Update Windows
Install Dell Fingertapps Touch Zone.
Install Dell Cozi YouPaint, Dell TouchCam, TouchCam Update
Install MS Touch Pack. Find here - http://forum.tabletpcreview.com/showthread.php?p=179262
Install MS XNA 3.0
Install MS Bing Virtual Maps 3D
Install Next Window Touch Screen Driver 1.3.2.5. Find here -http://www.nextwindow.com/nextwindow_support/download_confirm.html
Optional - Uninstall MS XNA 3.0, Install MS XNA 3.1
Sep 02, 2013 | Dell Computers & Internet
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Unknown to me, MS Office 2007 Pro Service Pack 2 downloaded and started to install. The first I knew was when I tried to open a Word document. It told me the instalation had failed. I have tried to...
Often when you try re-installing a program ontop of a program that is no longer working you will continue to have the issue, the best way to go about it is to make sure you've completely removed the program and the service pack before uninstalling it. First click start then control panel, then you're looking for either 'programs and features' or 'add/remove programs' depending on your version of windows. You should see Microsoft office there, as well as any service packs that have been installed for it. You may have to click 'view installed updates' on the left hand side to show the service packs.
Once you have completely removed office, as well as both service packs, and any other office patches listed. restart the computer, and begin a fresh install of office.
hope this was helpful.
May 31, 2011 | Computers & Internet
OK, Internet Explorer 7 or 8 will not work on my computer. It mysteriously stopped working. I use Firefox but sometimes I need IE. The page just says connecting, connecting and when it stops...nothing on...
Check your add-remove and see if Microsoft .NET Framework 2.0 service pack 2, 3.0 service pack 2, and 3.5 SP1 are installed. If not, you will have to go to windows update and get them if you want to use IE 8.
Jul 23, 2010 | Microsoft Internet Explorer 8
Windows XP Service Pack 3 disables Vuze from connecting
you should be able to uninstall SP by going into add/remove programs make sure show updates is checked, drill down to "Windows XP Service Pack 3" and remove..I'd also dump IE8..been known be a problem as well
from MS website,if that doesn't work there are alternate methods
http://support.microsoft.com/kb/950249
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Internet Explorer 8
hi,
when you open the trouble shooting icon that gives the exact message.
1. remove the traces of IE 8 if there are any.( start - run - IE8 - spuninst - double click on windows service pack uninstall.this is not applicabe for vista)
2. uninstall the security software completly. if its norton use the following link : www.symantec.com/nrt. it it's mcafee us this link: www.mcpr.notlong.com .
3. then install IE8. later install the security software back in the computer.
Jun 13, 2009 | Microsoft Internet Explorer 8
CAN'T INSTALL WINDOWS SERVICE PACK 3 (KB936929) and SONIC UPDATE MANAGER
All you need to do is open sonic update and disable sonic update manager from running automatically.Then reinstall the updates.
May 16, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Trend micro internet security 2008
Dear Sir/Madam,
This error will appear if you have installed the 16.05 version of
Trend Micro Internet Security Pro, Trend Micro Internet Security and
Trend Micro AntiVirus plus AntiSpyware 2008 on a computer running
Windows Vista with Service Pack 1 or Window XP with Service Pack 3.
The Trend Micro Personal Firewall and the Unauthorized Changes
Prevention features main components do not work with the new service
packs from Microsoft.
A working version of Trend Micro Internet Security Pro, Trend Micro
Internet Security and Trend Micro AntiVirus plus AntiSpyware 2008 with
Windows Vista SP1 and Windows XP SP3 would be released sometime in
February 2008.
The release would be timed before Microsoft uploads the new service
packs in their automatic update servers for Windows.
To prevent this message from appearing, follow the steps indicated
below:
a.Check the program version of the Trend Micro program installed on
your computer.
b.If you are using version 16.05 and you want to continue using this
latest version of the Trend Micro program, you must uninstall the non-
working service pack from Microsoft.
c. If you do not want to remove the new Microsoft service packs, Trend
Micro suggests that you uninstall the Trend Micro program installed in
your computer and install PC-cillin Internet Security 2007 until the
release of the working version.
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 06, 2008 | Trend Micro PC-cillin Internet Security...
Hello
the black screen at windows startup implies that u have a probleme with ur software package(service pack 2)
so get a fresh copy of the softwares u have mentioned
then 1st install windows serice pack 2 from the bootable disk
after that when windows starts install ms office professional.
below is the link to download windows xp sp2 and ms office2007 professional(better u use opera 9.25 version or higher version for download)
For windows xp sp 2-
http://www.mininova.org/get/1178630
For ms office proffesional-
http://dl.torrentreactor.net/download.php?id=1406943&name=MS+Office+2007+Professional+Plus+%2B+Expression+Web
after downloading xp sp2 ,burn it on disc using nero and then install from cd
Feb 27, 2008 | Microsoft Office XP Professional + Service...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
89 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
