Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Error code E11
Reads: 'Check water supply'
  • alan_mcinnes Mar 03, 2009
    Thanks for your help but I had covered those particular bases.
    Sniper:
  • 100 Answers
You will need to check there is water flowing with enough pressure and your hoses are not kinked.
sometimes there is a small filter at the entry to the hose connector which may become limescaled. these may be in the hose or the part of the machine they attach to.
Posted on Feb 28, 2009
  • daveeboy Mar 03, 2009
    looks likely the valves/wiring then
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
How do you fix e11 code?
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Sep 06, 2014 | Electrolux Washing Machines
What is E11 code?
Hello Friend, this is Z. Thank you for your post!
If you are receiving an error code E11, please check the following:
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
    ·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
    ·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
    Hope this helps!
Jul 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
Mar 29, 2014 | Eternal Hybrid Tankless Hot Water Heater...
Error code E11
Hello Elizabeth, thank you for your inquiry!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Oct 27, 2013 | Frigidaire Affinity FAFW3511KB 3.5 Cu. Ft....
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Oct 05, 2013 | Frigidaire GLTF2940ES Front Load Washer
Error code e11
if its a frigidaire front load washer then code e11 indicates thats its a slow fill water problem,remove your hot and cold inlet water hoses and check the hose screens for blockage
May 31, 2012 | Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Jan 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
On my Haier HWD1000, I keep getting error message E11... what does this mean?
Error E11 means either:
The water level can not
reach the reset water level
within 5 minutes
OR
reach the setting water level
within 8 minutes
What this means is check your water supply for sufficient pressure and if for some reason it stops and starts (eg. well drawn water with a small reservoir sometimes.)
You may have to make sure that there are no other water uses going on at the same time.
Jun 21, 2010 | Haier HWD1000
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
142 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
