Question about Jetway Computers & Internet
Pc shuts down during windows xp install
I have a new barebone system I put together myself. I am able to get into BIOS settings and everything is okay till I try to install my OS.
It will go as far as the first restart, then my pc shuts down and when I reboot, it starts windows installation all over. Everything is new and I have a good knowledge of pc hardware and installation. I have removed the RAM, one by one, rebooted and had the same problem. I have double checked all connectors and everything is installed correctly.
CPU - amd socket am2x2 5800+ /3.00GHz (new)
Heatsink and fan ( new )
HD - Seagate SATA 80gb ( new )
Memory - Kingston DDR2 pc2-5300 667MHz 4gb ( 4@ 1GB ) ( new )
Generic Power supply 450W ( new )
  • chuck Feb 27, 2009
    Thank you I will try that
  • chuck Feb 28, 2009
    Thank you very much for the help. I feel so dumb, I should have thought of setting it back to boot from the HD. That fixed it and everything is working good.
  • Jetway Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Posted on Oct 05, 2010
    President:
  • 1,073 Answers
Hi!
Easy problem to solve my freind:)
Do like this, start the installation as you did before, when your pc restarts, get in to bios again and change the first boot from cd/dvd to the HDD. That will solve your instalation problem:)
Good luck to you
Please take a moment and rate my help for you
Nic
Posted on Feb 27, 2009
  • Nicolas
    Nicolas Feb 27, 2009
    Pls do, i know it will work fien for you:)
    Let me know how it goes
    Nic
  • Nicolas
    Nicolas Feb 28, 2009
    U welcome my friend, im glad that it worked out for you:)
    Nic
Restore disk has been lost. I need to know how to change bios to allow straight Xp to be installed
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs.
If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
Jun 11, 2011 | Compaq Computers & Internet
When I will going to install win xp(sp2) with sata harddisk its show no dsrive installed on your system
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 15, 2011 | MSI MBOX K8MM-V Athlon64/Sempron Barebone...
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
I was defraging my c drive and the screen went blank. I have a PC with XP When it appeared the defrag was complete by no blincking lite I shut down and restarted monitor still blank
can you get into BIOS? if YES, put u'r bootable Windows XP CD into CD-ROM, and set BIOS to boot from CD-ROM..after some process you'll be asked to choose: install new OS or to do the recovery or exit
now pick option 2.
you will taken into DOS, type 1, it will appear C:>windows\ (type chkdsk)
C:>windows\chkdsk (enter)
after that type exit
C:>windows\exit --> good luck
Feb 08, 2010 | Microsoft Windows XP Home Edition for PC
During loading of window drivers the machine shut off.
go into systen bios and set the default leave it there for a good duration doing notheing. see if the machine dies if not save the setting and reinstall using the Boot from CD.
DO not Boot from HD
try a different CD drive unit too.
Jul 27, 2009 | Computers & Internet
Upgraded mem.now mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
Windows freezes when shutting down
If you can download the lastest bios for that PC from the internet that should fix your problem if that does fix issue reinstalling windows or does Xp restore from cds will
Mar 18, 2009 | Asrock K7S41GX Motherboard
Computer Shuts Down By Itself
It sounds like the heads that read your hard drive are deteriorating. If you have data that you need on the hard drive hook it up as a slave drive to another computer and save your data now. Because eventually you will no longer be able to access any data on the drive. Then you will have to send it to one of those data recovery places that use clean rooms to recover your data. That will be very expensive.
Or you might have a bad sector in bios. In that case, I am not sure what to do.
Dec 09, 2008 | Computers & Internet
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in bios  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
you need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Oct 25, 2007 | ASUS S-presso Standard S1-P112...
Computers & Internet Logo
328 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
