Thiis silly, but i just connected my dvd ton my dish satallite, and I don't know how to get it to play on my very old tv, my remote does not have a input button, how can I getb it to work?
  • trippgirl72 Feb 27, 2009
    the solution didn't come through
  • Jackie_T May 11, 2010
    Is the dvd a recorder? If not a recorder only a player then it has no input. You need to connect the dish satellite to your tv and the dvd player too. That way you can see the tv channels from the satellite and the player too. Connect the satellite to the coaxial cable /if possible/ and the dvd player to the RCA connection /or S-cart, depending which one you have on your TV/. Make sure the satellite and the dvd player are not connected.
  • 8,220 Answers
Download the Dish network remote control directions
Posted on Feb 27, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me do you want to record the programs by the dvd player/recorder or you want to just connect dvd player and dish cable box both with your tv.
You can use component cables to do this.
  • 13,433 Answers
The dvd needs to be connected to the tv then just turn the dvd to the satellite channel and you should have picture there.
  • 203 Answers
Does it have an av setting?
how have you plugged it into your tv?
  • sean sutton
    sean sutton Feb 27, 2009
    even an old tv will have an av setting. its for scart plugs. if you use scart the you need to use the av channel.
    if not the box will run through your dvd player channel or can be retuned to do so through your telly.
  • sean sutton
    did you solve your problem?
    one question, what does it say by the plug that you plugged your dvd into?
    and how does your sattelite plug into your tv?
Toshoba tv dvd combo picture on my tv will not work but picture on the dvd works great
I assume you mean you have a Toshiba TV with a slot for DVD play also. You don't say whether your TV is connected to a dish, cable box or antenna. Regardless of which it is, the fact that the TV produces a good picture on DVD but not on regular TV means one of two things: Either you have the TV hooked up incorrectly OR you do not know that you must change the SOURCE from DVD to TV to get a picture. That is done on the remote with the source button. Typically, the remote will have DVD, TV and AUX (one or more) as you cycle through them by simply pushing the source button again and again, If that doesn't work, you've got the TV hooked up incorrectly and/or it just happens to be set at DVD for the source. Normal hookup would involve HDMI out from the cable box, dish or whatever to HDMI in to the TV. Play with the remote "source" button. You'll figure it out. . .
Jul 02, 2017 | Televison & Video
I have a Samsung HLP5063. Just bought a Onyko AV receiver with HMDI hook ups. Also connecting Dish 211VIP, and Samsung DVD connected to the receiver. I was able to get the DVD player to work, but no...
Have you gone through your onkyo receivers setup manual. You will most likely need to adjust the settings on your Onkyo receiver. I also have an onkyo reciever and I have to assign the inputs to the video source. Being that you got sound out of the front speakes. I am assuming when you were playing out of the dvd player your reciever was only on stereo sound. Once I get feedback I can assist you further
Thanks,
Lee
Sep 28, 2008 | Samsung Televison & Video
Video no audio
Unplug the dish unit for 20 to 30 seconts an least, if you get to the settings screen select restore factory defaults.
Jan 22, 2013 | DISH Network Dish Satellite Tv...
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
I have recently had dish network installed and now I cant get my DVD player to play I have tried contacting dish network for assistance and no one can figure out the problem. I have a LG TV
Hello! This is Dan with DISH Network customer support. have you tried cycling the inputs? If you have an HD tv the DISH receiver and your DVD are probably connected using different cables. I would power them both on and hit the input or source button on your LG remote until you get a picture from the dvd player. Remember what input comes up as you will need to change this to go from satellite to DVDand back.
Jan 12, 2011 | Directed 434MHZ Remote Control
Can't use dvd on tv
when you hooked this up did you hook to the t.v directly? the dish receiver directly? or do you have surround sound system and hook through it. If you have a menu button on your tv then hit it, scroll to channel listings, once there you will be prompted to start selecting channels scroll down the channels to where it says video then select, that might work or least it does for me anyways. what type of tv do you have that could help me also. good luck let me know if i can help in any way
Feb 27, 2009 | Sharp Televison & Video
How to program my DISH Network remote to my DVD player?
It's kind of silly but I just pushed the VCR mode button, pressed the power on and off mode button & pressed the up button until the remote found the code. Took awhile but it finally worked.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
