Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Janome Excel 5124 reverse lever
Lever is stuck in reverse positioon and machine will not sew forward.
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
My reverse lever on my singer8280 feels stripped what do i do
Posted on Jul 11, 2009
Sews in reverse and then forward when the reverse lever is pressed.
Incorrect polarity at the plug, or the drive belt is crossed into a figure 8 so it is running the wrong way.
You can also try pushing the knob the right way as you depress the pedal.
Sep 16, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
How do I thread to use twin needles on Janome Excel Pro 5124?
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
Jul 27, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
Jan 15, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Instruction manual for Janome Excel Pro 5124
did you ever get a answer to the question you asked?
Jan 25, 2012 | Janome D'cor Excel Pro 5124 Mechanical...
Lost my sewing instruction manual when moving house. Can't remember stitch patterns adjustments. Need a new sewing manual for my Janome Decor Excel 11 5024 Thank you
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
Nov 16, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Backstitch isn't working
First, ensure that you are pressing the reverse lever all the way in and holding it. A light touch won't work on this model.
There is a spring loaded cam in the feed system which can get gummed up when the lubricant gets old. It needs to be carefully taken apart, solvent cleaned, re-lubricated and reassembled. A knowledgeable repair person needs to perform this operation.
Feb 21, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
1,643 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
