Question about Texas Instruments TI-84 Plus Calculator
T84 I want to class store notes and steps in the T84plus calculator is there a way to do this?
I always opened a new progam and typed whatever text, formulas, etc. I wanted to pull back up later. When you open your program option you will pull up what you typed in. This is a good way to organize information.
Posted on Feb 27, 2009
I ring they do not know it is me t84
Is there a question here? What is 't84'?
Dec 01, 2016 | Lands Phones
Fractions to a mixed number t84
If you have the latest OS, press the ALPHA key then use the F1 and select 2 Un/d
Feb 12, 2014 | Texas Instruments TI-84 Plus Calculator
Create a base class called shapes. use this class t store two double type values that could be used to compute the area of figures.dreive two specific classes called triangle and rectangle from the base...
Calculate area of triangle and rectangle. Get the values from the area function that is calculated by both classes then display that area using your own class.
Sep 06, 2012 | Acer Computers & Internet
How do i recieve answers on the El-W535x SHARP calculator in decimals, need it for buisness class...so if you could answer that question and tell me of any other functions i might be unaware of that might...
My name is adieh.have a great day.
I will give a simple example on how to convert your answer into decimal form. Indicated below:
Q: Simplify 1/2-5/13 convert to decimal
Answer:
Step 1: Enter 1/2 by pressing 1>a/b>2.
Step 2: Subtract by pressing - (negative sign or minus sign)
Step 3: Enter 5/13 by pressing 5>a/b>13.
Step 4: Find the difference by pressing = (equals sign)
Step5: Convert to decimal by pressing (change)
You can find( change) on the right side of your calculator beside M+ key
I am suggesting you to visit this website http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/Archive/cal_man_ELW535B_TeachersGuide.pdf
for you to have further knowledge about various functions of your sharp calculator since you are attending a business/algebra class.
Hope it helps.
Thank you for using fixya.
Sep 22, 2011 | Office Equipment & Supplies
Our t84 won't hold any battery life. we have changed both the lithium and the tripl a's and you can only use the calculator one and then its out of battery......what is going on?
Possibility: Some third-Party programs (games essentially) are installed on the calculator. They may be ill-designed and circumvent/turn OFF the Power saving features of the calcuator.Also, Texas Instruments recommends to use alkaline (non-rechargeable) batteries only.
Sep 16, 2011 | Texas Instruments TI-84 Plus Silver...
How do i get rid of shadeRes in my window T84
You might have activated the application called Inequalz. It solves inequations. One of its feature is the shading of solution regions and the resolution of the shading is called ShadeRes. When you press the Window function key you see the ShadeRes value before the usual window dimensions.
To get rid of the Inequalz application (kick it out of memory without removing it completely from calculator)
  1. press the Apps key.
  2. Use downArrow to put focus on Inequalz and press ENTER
  3. In the new screen that is displayed "INEQUAL RUNNING" select [2:Quit Inequal].
Jul 30, 2010 | Texas Instruments TI-84 Plus Calculator
Error code t84 ???????? anyone
Hi stuiejohnsto,
As far as I know there is no error code t84. The closest code that has the numbers 84 in error code CC-184.
Anyways, whatever code you may have, it's worth turning the machine off for 10 seconds by the Main ON/OFF swich (inside front door on the left).
With any luck your code should disappear. If not, can you let me know if it gives you a different code to t84
Thanks
Good luck
Tam
Mar 22, 2010 | Konica Minolta Bizhub c203 Copier
STORE NOTES
you can go to PRGM and create a new one. and store info in there.
Feb 27, 2009 | Texas Instruments TI-84 Plus Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
265 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
