Question about Linksys Wireless-G Broadband Router
Intermittent or slow internet connection
Using Linksys Wireless Router, having slow or intermittent internet connection.  Internet pages will either time-out or open-up very slowly.  Occasionally, the internet connection will be dropped.  Problem started about one month ago but seems to have gotten worse in last few days.
Signal strength is excellent.  Reset router by unplugging, turning off power, let sit for 1 minute, then restart; no improvement.
Using Dell Latitude D820 laptop that works fine at other wireless locations.  Local desktop with LAN connection is working fine.
  • mdaniels261 Mar 24, 2009
    My linksys wireless router works perfectly with a desktop and one of my two laptops. All units run WinXP. One of the laptops has intermittent internet connection through the wireless network; for 10 minutes it works perfectly, then it simply stops working, although the signal strength is excellent and the laptop reports it is connected to the network. Could it be a problem with the network card on that laptop?
  • Anonymous Mar 29, 2009
    I am having the same problem but it seems that it always get disconnected. IT always says "the network connection cable is unplugged" on the system tray, but then it will automatically reconnect itself as nobody is really touching the network cables and they are correctly attached. I tried to switch cables but the same thing happens.
    Scholar:
  • 61 Answers
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Posted on Feb 27, 2009
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
I need to modify the settings on my router so that I can get a better signal on my internet radio. The current signal is low and I keep losing my wireless internet connection.
You can follow the step by step procedure to correct this intermittent wireless connection on your router by following the steps from my TIPS , just click HERE.
Aug 28, 2011 | Linksys Wireless-G WRT54G Router
I have to reset (unplug power, wait 10 secs, then plug back in) a lot to have internet access. The router is recognized and it says that I am connected, however it also says that I have no internet...
There are lots of factor why you have that kind of problem when it comes to your router. Before following the steps in this, check if your computer has a stable Internet connection when connected directly to your broadband modem. If you do not have a stable Internet connection with your modem, kindly contact your Internet Service Provider (ISP).
May I know what is the model and version of your Linksys router?
If you run into Intermittent Wired Connections Using a Router:
Step1: Enabling MTU on the Router
- Access the router's web-based setup page.
- Open a web browser such as Internet Explorer.
- Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
- A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
- NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
Step2: When the router's web-based setup page appears, look for MTU and set it to Manual. Enter the MTU value of your Internet connection in the Size field.
1468. The size DHCP or cable providers prefer.
1400. Maximum size for DSL.
Step3: Save settings.
If you run into Intermittent Wireless Connections Using a Router:
Check if your wireless computers have stable connection when connected to other wireless networks.
Regular wireless disconnection can be caused by different factors such as:
> Wireless interference within the network.
> Wireless settings of the Linksys router are still set to default.
> Firmware is corrupted.
NOTE: If the procedure does not work, needs to update the router
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
I just moved into a new apartment and I am currently attempting to use the same linksys router that I used at my old place (without difficulity). My lap top in the bottom right corner displays...
> excellent connectivity
This refers to the wireless connection between your computer & your router, not to the connection from your cable-modem (or DSL-modem) out through your ISP to the Internet.
If you use an Ethernet cable to connect your computer directly to the cable/DSL modem, do you still have "intermittent" problems?
If so, then your router (or other wireless devices, such as your neighbours' router, or your neighbours' wireless telephones that are trying to operate on the same broadcast frequency) is the problem.
Aug 21, 2010 | Linksys Wireless-G WRT54GS Router...
I am getting intermittent internet connection
IF you are using a Wireless Router and having intermittent Connection then change the Wireless channel of your Router to 9 and also check the firmware version of the router, it should always run on the Latest version.
Mar 17, 2010 | Linksys Wireless-N WRT150N Router
Wireless signal from belkin n1 low even with dlink booster usb
try using wireless N routers .. gofor linksys Wireless ' N '..this gives u the best possible range other than wireless b/g..hope this helps...
Jul 08, 2009 | Computers & Internet
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
My net is airtel broadband but it connected through liksys router
You might be getting intermittent connection. What is the exact model and version of your router? check your firmware. It might need to be upgraded. =)
Jan 19, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
291 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
