Question about Texas Instruments TI-84 Plus Calculator
STORE NOTES I have a T84 cal is how do I store class notes and steps in the calculator? like P=R-C ?
  • 11 Answers
You can go to PRGM and create a new one. and store info in there.
Posted on Mar 01, 2009
Fractions to a mixed number t84
If you have the latest OS, press the ALPHA key then use the F1 and select 2 Un/d
Feb 12, 2014 | Texas Instruments TI-84 Plus Calculator
How do i recieve answers on the El-W535x SHARP calculator in decimals, need it for buisness class...so if you could answer that question and tell me of any other functions i might be unaware of that might...
My name is adieh.have a great day.
I will give a simple example on how to convert your answer into decimal form. Indicated below:
Q: Simplify 1/2-5/13 convert to decimal
Answer:
Step 1: Enter 1/2 by pressing 1>a/b>2.
Step 2: Subtract by pressing - (negative sign or minus sign)
Step 3: Enter 5/13 by pressing 5>a/b>13.
Step 4: Find the difference by pressing = (equals sign)
Step5: Convert to decimal by pressing (change)
You can find( change) on the right side of your calculator beside M+ key
I am suggesting you to visit this website http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/Archive/cal_man_ELW535B_TeachersGuide.pdf
for you to have further knowledge about various functions of your sharp calculator since you are attending a business/algebra class.
Hope it helps.
Thank you for using fixya.
Sep 22, 2011 | Office Equipment & Supplies
Our t84 won't hold any battery life. we have changed both the lithium and the tripl a's and you can only use the calculator one and then its out of battery......what is going on?
Possibility: Some third-Party programs (games essentially) are installed on the calculator. They may be ill-designed and circumvent/turn OFF the Power saving features of the calcuator.Also, Texas Instruments recommends to use alkaline (non-rechargeable) batteries only.
Sep 16, 2011 | Texas Instruments TI-84 Plus Silver...
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
How do i get rid of shadeRes in my window T84
You might have activated the application called Inequalz. It solves inequations. One of its feature is the shading of solution regions and the resolution of the shading is called ShadeRes. When you press the Window function key you see the ShadeRes value before the usual window dimensions.
To get rid of the Inequalz application (kick it out of memory without removing it completely from calculator)
  1. press the Apps key.
  2. Use downArrow to put focus on Inequalz and press ENTER
  3. In the new screen that is displayed "INEQUAL RUNNING" select [2:Quit Inequal].
Jul 30, 2010 | Texas Instruments TI-84 Plus Calculator
Error code t84 ???????? anyone
Hi stuiejohnsto,
As far as I know there is no error code t84. The closest code that has the numbers 84 in error code CC-184.
Anyways, whatever code you may have, it's worth turning the machine off for 10 seconds by the Main ON/OFF swich (inside front door on the left).
With any luck your code should disappear. If not, can you let me know if it gives you a different code to t84
Thanks
Good luck
Tam
Mar 22, 2010 | Konica Minolta Bizhub c203 Copier
I need the manual/s for a Cobra CB radio, 29LTD Classic,ser#105129711,manufactured 5/01. Thanks for any help you might have, This radio has a built in SWR meter and I need to know how to tune it or do I...
1) push the button marked S/RF / SWR / CAL to CAL
2) Hold in the button on the mic
3) Turn the SWR CAL knob until the needle is over set to the far right of the meter
4) flick the switch (in step 1) to SWR
Your SWR reading will be displayed. The more to the left the better..
Jun 22, 2009 | Radio Communications
T84
I always opened a new progam and typed whatever text, formulas, etc. I wanted to pull back up later. When you open your program option you will pull up what you typed in. This is a good way to organize information.
Feb 27, 2009 | Texas Instruments TI-84 Plus Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
546 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
