Question about Shimano Brake Cables Atb Mountain Bike Cable Box 100 Ss
Adjusting front derailer
Adjudting the front derailer
  • 21 Answers
Typically adjusting the front derailleur is a matter of adjusting the two adjusting screws on the derailleur. So turn the bike upside down. It should sit on its seat and handle bars. Find the two adjusting screws one will prevent the derailleur from traveling too far out preventing the chain from coming off. The other screw prevents the derailleur from traveling too far in keeping the chain from falling off that way. Now once you have found the screws slowly start turning the pedals like it was being ridden. Move the derailleur out as far as it will go if you see the chain is about to come off adjust the screw. Do same for inside screw. Now move the back derailleur all the way in and retest front derailleur, repeater with rear derailleur all the was out. Hope that helps. Oh, the back derailleur adjusts same way.
Posted on Feb 28, 2009
How do i adjust front and rear deraillers on a giant nrsxtc3?
See links below. Best to study written instructions first, then look at YouTube videos to see the procedure (just Google what you want to see, such as adjust front derailleur, and click on "Videos." Many videos are inaccurate or leave out steps, so I do not recommend going only by them. Even better, if you have a bike co-op nearby, or a bike shop that has repair clinics/classes then try that out. In-person assistance is always best.
Repair Help and Education
Derailer Adjustment
Dec 18, 2016 | Giant Cycling
HOW DO I ADJUST FRONT DERAILER
loosen the screw holding the cable to derailer, then extend or shorten the cable distance as needed.
Apr 21, 2015 | Genesis 26 Inch V2100 Dual-Suspension...
Ezip
Since you didn't specify which derailleur needed adjusting, I have included links to adjusting both the front and rear derailleurs.
Park Tool Co ParkTool Blog Front Derailleur Adjustments
Park Tool Co ParkTool Blog Rear Derailler Adjustments derailleur
Apr 13, 2014 | Cycling
Won't shift past 4th gear since I replaced front and rear tires
make sure that you the brand od derailers and the derailers can be adjusted. there should be 2 screws on the derailer to adjust them.
Sep 26, 2013 | Giant Bicycle Inc. Revive DX
I have a Kawasaki kx20s 10 speed boys mountain bike that needs the rear brake cable replaced and both the front and rear derailer gear cables adjusted or possibly replaced. Is there a manual or diagram of...
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Aug 26, 2011 | kawasaki KX20 Boy's BMX Bike
How to adjust the front mech - changing to the larger wheel requires maximum sweep and a bad change to the smaller ring - when the chain is on the largest sprocket -results in the chain coming off. thank...
Turn one of the two screws on the top so that the mech. (derailer) moves toward the frame a fraction of an inch. Keep adjusting this until it doesn't fall off.
Jul 13, 2011 | Campagnolo Centaur QS
My daughters mt sport sx roadmaster bike keeps changing gears and making a clicking sound. What causes this?
phililisa03-
This problem is caused by improperly adjusted derailers/shifters, the mechanism that move the chain from one gear to the next. It is not uncommon for the derailers to be out of adjustment after sitting unused through the winter. Over time the cables that run between the shifters and the derailers stretch just a bit and the derailers no longer work as well without a little tuning up. Unfortunately, for the novice, adjusting the derailers is frustrating at best. The effort and patience it requires is nothing to take lightly. If you're game for giving it a try, there are a number of websites out there that will provide extensive guidance on the process - just "google" how to adjust bike derailers" and you will find plenty of options. My local bike shop will make adjustments like this for a small set price, around $20 or so - you may have a shop nearby that will do the same.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Roadmaster Cycling
The front derailer will not stay in gear. It
check the shifter handles also check your cables and cable covers check anchor bolts frame clips anything that can cause your cables to come out of adjustment shimano is quality stuff so start at the shifters and work back to the derailleur .hope this helps
Nov 23, 2009 | Shimano Deore LX Mountain Bike Front...
Shimano Brake Cables Atb Mountain Bike Cable Box 100 Ss Logo
722 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
