Question about Panasonic Electronics - Others
System is dead
When the home theater system PANASONIC SA-H700 is connected up there is no output onthe speakers in fact there is nothing displayed on the receiver not even a power light.
  • philerz Mar 30, 2009
    DID WHAT YOU SAID BUT HAD NO LUCK.
  • 10,594 Answers
Seems power supply failure problem.
Please unplug unit for couple of minutes, replug back in and check.
Post back comments to help you in case required power supply board replacement.
Posted on Mar 08, 2009
  • Panasonic Master
  • 19,396 Answers
Try a different power outlet, if still no start, then the unit has a defective power board.
  • Ginko
    Ginko Mar 08, 2009
    If the unit does not start at all, then it means no power is getting to the unit.
    Try first a different power outlet.
    If the power cable is fused, like in UK, replace the fuse in power cord.
    If still no luck , then the power supply circuit inside the system is faulty, usually this happen because one of the capacitors on power board has blown.
    If instead you have the led on the system, and you have power , but system is irresponsive, then the system is in protection mode because it had detected an internal fault.
    In that case the unit must be disassembled and tested thoroughly by a technician to fix the problem.
How do I use the aux setting to play music from my iPod or phone on my home panasonic sa-ak220 stereo?
you'll need a lead to split the headphone output to a pair of phono leads to plug into the back. the manual is here
May 02, 2012 | Panasonic Electronics - Others
How do i connect the TH-M606
Do you mean JVC???? It's in the manual.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M606J-Home-Theater-Systems-manual/id/318dj490/t/2/
Jun 23, 2011 | JVC Electronics - Others
PANASONIC SA PT 450 5 AMP INTERNAL FUSE BLOWN SHOULD I JUST REPLACE OR IS IT PROBABLY A MAJOR PROBLEM
Worth a try! If it blows again, that will be a semi-conductor that is acting like a piece of wire that is causing the problem.
Jan 01, 2011 | Panasonic Electronics - Others
BEO2300 CD not playing and LH speaker inop
I am sorry that your cd player must have a weak laser output, the optiical headd is defective if you have tried to clean and not had any result. clean one again to confirm. Now the next thing you must do is to put your set on for another 24-48 hours. let the electronics within get charged up. try it out after 12 hours, 24 hours and so on. If this wont clear then your Cd optical needs a change. Now regarding your L channel , it is important to see if the speaker connections are tight if your L speaker works in the R side then the speaker is fine. if not check if your speaker is faulty and replace. if not check within the amp for a faulty L output amp circuit. I hope the set will power on after some time. Good day
Jun 26, 2010 | Electronics - Others
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
We have run our indoor/outdoor wireless speaker through our home theater system and the only sound we can get is in tuner mode. We are trying to run our tv through the speaker, any suggestions?
connect audio out from tv to audio in(aux in) on the theater, select aux on theater and you should get sound.
If you have no audio out on tv, use skart 2 (av2 au2 or how ever it's marked as most tv's send audio/video out through av2).
You can buy any comination leads to connect(skart to phono etc)
Aug 08, 2009 | Electronics - Others
Samsung ht-x50 home theater system keeps shutting off
You have probably set the sleep timer. Here's how to switch it off: To cancel the sleep timer, press the SLEEP button until <OFF> appears on the display.
Jul 07, 2009 | Samsung Electronics - Others
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
Apr 09, 2009 | Panasonic Electronics - Others
Home theater
Check to make sure that your speakers' ohm rating matches the amp.
Also check every speaker connection carefully for stray strands, poor connections, etc.
Aug 22, 2008 | Electronics - Others
Electronics - Others Logo
46 people viewed this question
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Rob Wheeler
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
