Question about HP DeskJet 5150 InkJet Printer
Print quality reduced.
HP 5900 inkjet. Just replaced both cartridges. Was printing beautifully - sharp and color saturdated - prior to change. Message said both cartridges installed successfully, but print is now definately not as good as before. Using HP cartridges, not refills. any suggestions?
    New Friend:
  • 52 Answers
You probly have a cloged cartridge. Most of HP's cartridges are water based ink. Take the cartridge that is not printing good, color or b/w, set the copper colored end, which is the print head on a dry paper towel. You should be able to see all colors as a solid line, or the black will show 2 solid black lines. The one that is not correct, take a paper towel and get it damp, and set the print head on the damp towel, be sure to fold the towel or it will stain the table you set it on. and let it set for a few minutes. Try the dry towel again. You may have to do this several times..You also should have software to prime your cartridages. After cleaning, try to prime the cartridge.
Posted on Feb 27, 2009
How do I change the toner HP Officejet 6310 All-In-One
Hi, the officejet 6310 takes ink and can be ordered from most online stores like staples, cartridge world and amazon, All will vary in price, but always stick to the official HP inks although they are more expensive the compatibles do cause problems. below is a link to the cartridges you will need to purchase.
http://shopping.cartridgeworld.co.uk/home.php?cat=901
Unfortunately i cannot attach files to this message otherwise i would put the manual on here, which on page 95 shows step by step on how to change the ink cartridges. I can email this to you if you provide an email address for me. below i have copied the instructions from the manual, but there missing illustrations, so might be a bit hard to follow. please let me know if you require any further help.
Replace the print cartridges
Follow these instructions when the ink level is low.
Maintain the HP All-in-OneNote When the ink level for the print cartridge is low, a message appears on
the display. You can also check the ink levels by using the software installed
with the HP All-in-One.
When you receive a low-ink warning message on the display, make sure you have a
replacement print cartridge available. You should also replace the print cartridges
when you see faded text or if you experience print quality issues related to the print
cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
Tip You can also use these instructions to replace the black print cartridge
with a photo print cartridge for printing high-quality color photos.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
1 Print cartridge door
2 Print carriage
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 10
96 HP Officejet 6300 All-in-One series
Maintain the HP All-in-One1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 97
Maintain the HP All-in-One7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
12. Press OK.
Dec 02, 2011 | HP Officejet 6310 All-In-One InkJet...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
When i print a document, part of the print will be perfect, a couple of sentences, and then several sentences you cannot read at all, its too light or part of the letters are missing - for instance on an...
Follow the steps below to perform basic print quality troubleshooting.
1. Check your paper and verify that the all-in-one has clean, white, inkjet-rated or multipurpose paper in it. In many cases copier grade papers or paper specifically for Laser printers should NOT be used. These papers are frequently coated and are not intended for dye-based inks. The paper container should also have a brightness and weight listed on it. Generally speaking, the brighter and heavier the paper, the better the printout will look. HP recommends papers with at least 90 brightness and 75 g/m2 (20 pound) ratings.
2. Verify that the all-in-one is on a firm surface that fully supports its weight and does not move as the all-in-one prints. If the all-in-one is placed on a desk or other surface that is free to move or shake as the all-in-one prints, the printout will not look as good as it should.
3. Refilled or remanufactured print cartridges will often produce inferior results. HP will not support any print problems that result from the use of remanufactured and refilled print cartridges since their quality is not in HP's control. If you are using refilled or remanufactured print cartridges, replace them with a new HP print cartridge.
4. Print a self-test page from the all-in-one to verify that the all-in-one is working correctly. If the self-test prints correctly, go to Step 3. If the page does not print correctly, verify that the ink cartridges have ink in them. Then, unplug the power cord from the all-in-one, wait five seconds, and plug it back in. Contact HP for assistance if a self-test page still will not print. To print a self-test page, follow the step below:
5. Press SETUP (or MENU ) until " Print Report " displays, then press ENTER .
6. Examine the self-test page printed by your all-in-one.
i. If the colors are correct and the text is sharp and clear on the self-test page, the problem is not the all-in-one or the print cartridges. The problem is the print settings, the file being printed, or the program you are printing from. Continue to step 7 below.
ii. If the colors on the demo page are not correct or are missing, review HP document Printed Pages Are Missing One or More Colors but No Error Message Appears (buu02176) (in English).
iii.If the printout is not sharp or clear, skip the remaining steps in this section and review the remaining information in this document.
7. Try printing the document again but try changing the print settings by following these steps:
1. Within the application you are trying to print from, click File and then click Print . This will bring up the print screen.
2. Verify that the correct printer is selected and then click Properties .
3. On the Quality tab, verify that the correct paper type is selected, and then change the Print Quality setting to Best . Verify the settings on the remaining tabs are correct and then click OK .
4. Print the file you were trying to print again.
i. If the problem is corrected, the problem was the print settings. There is no need to continue troubleshooting.
ii.If the problem still exists, try printing on different paper.
8. Print a different file or image. If you have a file that printed well in the past, try printing that file. Low quality originals will not print very well. Screen captures and images from the internet are often at around 75 dpi. These images are at too low of a resolution to print well. If the self-test page looks good but your image does not, even after changing the print settings, the problem may be the original file. Cheers!!
Apr 21, 2009 | HP PSC 2175 All-In-One InkJet Printer
Color Ink Cartridge Problem
Unplug the printer, and leave it unplugged for 5-10 minutes. Then if the printer is still complaining about the color cartridge when you turn it back on, then replace the print cartridge.
David
Dec 04, 2008 | HP Photosmart 2575 All-In-One InkJet...
Color cartridge problem
The first thing I thought of when I read your message, was whether or not your replacement cartridges were produced by HP or by another company. Also, was it a brand new cartridge or a refill? While buying ink cartridges from another vendor or "recycled" cartridges may save a buck or two, you can't always rely on the quality of the printouts they produce. If this is the case, try using an HP color ink cartridge and see if that produces better print quality.
If you are using HP ink cartridges, there might be an issue with the contact between the cartridge and carriage. It's an electrical connection and if the contacts get dirty, it can affect print quality...sometimes drastically.
Unfortunately, HP.com doesn't have a web page dedicated just to cleaning these contacts. Fortunately, they included those instructions in the following document:
Replacing the Print Cartridges
When the web page opens, scroll down to the bottom of the page and locate the task, "Fixing error messages that appear after changing a cartridge". This will contain instructions on how to clean those contacts. See if this helps.
If all else fails, try going to the following web page:
Correcting Print Quality Problems
This is sort of a "catch all" web page with a large collection of print quality diagnostic and repair techniques. If you've gotten this far wtihout a solution, perhaps something on this page will help.
Good luck.
Oct 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer
your computer screen. You can also check the ink levels by using the software
installed with the HP All-in-One.
When you receive a low-ink warning message, make sure you have a replacement
print cartridge available. You should also replace the print cartridges when you see
faded text or if you experience print quality issues related to the print cartridges.
them.
The print carriage moves to the center of the HP All-in-One.
slot on the left.
Chapter 8
28 HP Deskjet F300 All-in-One series
connections.
User Guide 29
9. If the print cartridge alignment sheet prints, load it on the left front corner of the
glass with the top of the page to the left.
10. Press the Scan button.
Oct 29, 2007 | HP DeskJet F380 All-In-One Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
155 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
