Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer 220v LEQ8611LW1. Runs but no heat. Difficult to get good repairwork here in Mexico. Housekeeper allowed lint trap to get 1" thick - no removal. Repairaman got it working without taking the dryer apart on two occasions. Last time he replaced thermostat. It runs for a few times, then heat disappears like before.
  • Whirlpool Master
  • 19,396 Answers
Test the connections from the control board to the heating element.
Posted on Feb 27, 2009
  • Ginko
    Ginko Feb 27, 2009
    Start testing the heating element, and the connectors to the element, the problem may be a bad wiring to the element that stop heating when loses contact because of vibration.
    Check also the connections from wiring harness to heating element on control board side.
    If the element and the wirings are fine, check that it is not a fan problem , try to understand if the fan is running.
    If nothing in there, test and eventually replace the thermistor.
    If it is none of the above , then you have a defective control board.
    You can find replacements and diagrams for your model by entering the model number here.
  • Ginko
    Ginko Feb 27, 2009
    Click below to open diagrams, refer to my previous email to find instructions on how to proceed:
    To test continuity on the heating element you will need a Multimeter
    Always work with power unplugged, there is AC inside your appliance.
Ml1987295
I will assume that you have cleaned the lint trap and checked that there is no lint stuck in the lint trap cavity
First, check the dryer vent. Any blockage anywhere in the vent will stop air flow. A dryer needs air flow to dry. Check every bit of it, even where it goes outside.
if that isn't the problem, then check your electrical connections. Your electric dryer runs on 220 volts, but it's really two wires carrying the electricity to the dryer at 110 volts each. If one of those wires isn't connected, the dryer could still turn on and spin, but it won't dry the clothes.
I learned that the hard way going through 2 dryers. Turned out one of the fuses in my apartment's fuse box had blown, but 2 fuses made up the 220v circuit. The dryer would spin and would work a little bit on low settings, but any other setting it would just spin and not dry at all. Replacing the fuse fixed the issue. With a breaker box, the 220v double breaker is connected, so if one trips, they both trip, and it wouldn't spin or turn on at all.
So check the socket with a multimeter (or have an electrician check it) and unplug and check the dryer cord making sure each connector is securely screwed in to the panel on the back. There is typically an access panel on the back of the dryer right next to where the cord goes in that you have to take off to get to the connection panel.
The last thing I would say a DIYer could look at is the heating element. If you take the back off, you can access the heating element and see if there is any lint or debri in there... if there is, clean it out and try the dryer... if it still doesn't work but there was debri in the heating element's channel, it could have burnt up a safty sensor that shuts the heating element off when it senses too much heat (fire, or potential to cause a fire) I suggest using and appliance repair man at this point.
Jul 31, 2014 | Whirlpool Dryers
Cabrio gas dryer heats then has a strange smell when heats up
I had the same problem. It turned out to be that the lint trap wasn't filtering properly. I had to unplug and turn it (dryer) over. Open it up from the back and found. The entire inside of the dryer was covered with a thick layer of lint. That was begining to burn slowly. If you clean it yourself. You are going to need a socket wrench, vaccum cleaner w/ a long hose or lint lizzard (extention for the hard to reach places) large trashbag, about 3 to 4 hrs, and plenty of patients. Make sure you don't accidently disconnect any wires.
Jun 06, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
Dryer will not dry clothes.
I assume it runs and this is from that stance. If it doesn't the motor has to be checked and the power coming in. In fact the dryer can run and still not have the correct power to opperate the heater.
Assuming you have a volt meter and know how to use it properly.
These are the steps that the power and machine have to take to operate properly
A. If the dryer has all of these things it has to be heating and an air flow problem (kinked or dirty dryer duck, motor fan clogged with lint, vent flapper not opening...) is suspect.
B. ELECTRICAL
1. power is correct (USA 220V across line and 115v to ground/neut) 2 hot lines with potential between them and a neutral and possible a ground
2 Door switch is closed
3 Timer switch closes and ready s power to heating element through centrifugal switch in the motor circuit after the motor is running.
4 the heating element is assumed to be good and have 220v at this point. Checking for voltage at the element will assure all before are ok and at least allowing the heater to work.
5 the heating element is controlled by 1 or more thermostats and a safety thermostat. If either of these switches do not close when the dryer is "cool" they are bad. NOTE some dryers could ahve 3 wire thermostats. These can read closed on one set and open on the other. And this is how they should be if good. But tracing the wire diagram will tell which set is closed and when.
6 if you have power, the timer contacts to the motor and the heater (separate circuits usually)are "closed", the motor runs, the cent switch "closes", the temperature operating thermostats are closed, and the heating element is good you have to have heat.
1 Check for 220V power into the dryer. If not check breakers and turn off and on several time pushing them firmly. If this is ok and 220V present step 1 is done.
2 This assumes the motor will run
Nov 01, 2010 | Whirlpool LER4634J Electric Dryer
Gas dryer not heating all the time
Good Luck!!
Jan 27, 2010 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Apr 20, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
408 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
