Question about Gigabyte GA-8SIMLH Motherboard
My power supply is ok. but motherbord can't conected the power. i was try on bord power pin short, but motherbord can't find power.
    Problem Solver:
  • 11 Answers
What do u mean, can't connect the power?
Posted on Mar 01, 2009
I forgot the way to connect the cables to the motherboard,after i removed them.Especialy start and restart buttons..can u help me?
we give power to fan from mother there there3/4 pin squiri white potr.we give power to bordfrom smps 9/12 white squite connecter.we join power/ led/ reset /usb cable between casing and mother bord. we can see this thing written in motherbord and wire connecter(small)
Oct 31, 2009 | Matsonic MS9158EP (DSMTSMS9158EP)...
Possible short on motherboard
You can look for faulty components on board with an ohmmeter on the ohm setting. Check each connection to see if there is any resistance ratings.
Aug 27, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Have a ATA-100 motherboard, when turning it on it turns itself off within 3 seconds... do not have a manual with this.
Pull cmos cell from motherbord for 10 minutes refix RAM memory .
reconnect all conection to motherbord.
Check your home power supply working fine also check earthnig ground problem.
Some times your smps means your cpu power suply unit has issue.
So try with other smps it is square box on top of the cpu in back side.
Aug 18, 2009 | Intel Motherboard
MSI N 1996 MOTHERBORD DO NOT START SMPS OK
Hi this might not be a motherboard problem. Remove the memory card and clean the contacts and reinstall it. If this will not work for you replace the memory card with the same type you have in your computer. Hope this info will help you solve the problem
Aug 15, 2009 | Intel Motherboard
New motherboard won't power up
First check your motherbord POWER pin it is in corner of motherbord.
Just short that 2 pin with screw driver .
Read on motherbord corner you can find pin for Power up.
also reconnect cable from psu to motherbord.
Aug 01, 2009 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
Mother bord not a display
have you a graphics card you could use? if so you could try re-installing graphics drivers for the onboard graphics.
if not, to test the video output you would need a post test card, available for approx £15. this would enable you to test your motherboard completely.
Feb 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
mother board
not display show
Oct 19, 2008 | MSI K8MM-V Motherboard
check different working ram, also take out the cpu fan then place it again, then check
Oct 19, 2008 | Intel D845GVSR Motherboard
Pc wont stay on
check your power supply,earhing problem .proper voltafe .
clean your ram,processor and its position.
check that your bord dont touch the cabinet.
other wise i think your bords register or diode transistor are corrupt.
repair your motherbord chipset if above try are not succes
Apr 01, 2008 | Soltek SL-86SPE2 Motherboard
Gigabyte GA-8SIMLH Motherboard Logo
137 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
joecoolvette
joecoolvette
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
