Question about Schumacher & Fast Charge Starter Charger
Forgot to plug my car in last night & now my battery is dead!!
I am using a schumacher battery cahrger/ starter model no SF-1252-MA. I am using the 10 a setting and is on conventional mode.. How long will it take to charge battery enough to start it up?? I need to be somewhere in3 hours. is this going to be enough time?? I also plugged in my heater core thats never been used before. My car is a 1992 grand marquis LS. I hear no noises coming from it.. It has never been used. How do i know that it is actually working?? How can I tell??
2 Suggested Answers
  • 3 Answers
SOURCE: schumacher battery charger sf-1252-ma thermal fuse
The thermal fuse (1 shot fuse) is a #U25 from
Uchihashi Corp. The link below will take you to their page showing the fuse type and ordering information. Probably not found at a local electronics store.
http://www.uchihashi.co.jp/english/image/pdf03ae.pdf
Posted on Mar 03, 2011
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
I have an completely dead car battery and i need to know which setting is required in order to use the 2/15/125amp starter charger?
Disclaimer - I accept no responsibility for anything I say here. I may be wrong, so use your judgement on taking my advice.
Advice - First try the web and/or the manufacturer for the manual for the charger - if that fails, what I'd do for myself is...
125 for starting the car (ONLY, not charging the battery) 15A for charging dead/low battery 2A for maintaining battery
If 125 doesn't start the car, I'd call AAA
Feb 11, 2011 | Schumacher & Fast Charge Starter Charger
Schumacher battery charger sf-1252-ma thermal fuse does anyone know what the number is off of this fuse
Nov 20, 2010 | Schumacher & Fast Charge Starter Charger
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
1987 Audi 5000s won't turn over
Do you have headlights if you turn them on. Sometimes if a battery is clear dead and you jump it and it will depend on the gauge of wire in the jumpers whether it will start right off or not. Another scenario is the battery you bought is not good or fully charged. If you have a battery with less than 11 volts it probably won't energize the starter.
Apr 03, 2017 | 1987 Audi 5000 CS
Where are the fuses and relays for the fuel pump and starter?
sorry sir my computer crashed on me last night i finally got it going again . now you have the 1989 lincon towncar. darn i thoutht it said 1999 last night. anyways no problem, that year they did not have a relay for the starter . what they had was a starter solenoid located on either the fire wall or the fender, just follow the wires from the starter up to the solenoid im betting 10 to 1 your problem is in that nifty device. now you can check it to make sure it is the problem with a screwdriver just take the little wire (it just plugs to it no nuts holding it on ) and touch it with the screwdriver now at the same time touch( while still touching the little probe)the large wire (coming from the battery) if nothing happens then the solenoid is bad, just for grins to see if the starter is working touch both big terminal at the same time and watch her spin over if it doesnt then starter is bad or the battery is dead good luck and sorry for the delay i appreciate your patience
Aug 28, 2008 | 1989 Lincoln Town Car
Schumacher & Fast Charge Starter Charger  Logo
114 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
