Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
8.8 kenmore chest freezer
How long til cold enough to put frozen food in
  • Kenmore Master
  • 8,220 Answers
24 hours
Posted on Feb 27, 2009
The chest freezer was open wide for 24 hours before I noticed it. Will I have a problem with the unit or will it be fine
as cold air sinks to the lowest point it would have been operating a little longer that if it was closed I would think that it will be fine
example chest freezers in supermarkets only have plastic sliding lids and the ice creams and other frozen foods are still frozen
Apr 28, 2016 | Freezers
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
Oct 26, 2010 | Whirlpool Freezers
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Kenmore Freezer chest type 14.8 cubic feet
When you open the freezer compartment do you hear a fan blowing? If no the take off the back cover and replace the fan. The compressor has to be on at the same time for the fan to work. If you know what I mean. let me know what happened. thanks.
Nov 24, 2008 | Freezers
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
My bottom drawer won't open?
Can you supply more info? Was there food in there that could have frozen in a position to lock up the door slides?
Oct 24, 2006 | Kenmore 4.8 cu. ft. / 136 liter Chest...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
123 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
